跳转到主内容
Audio-Technica LP60XBT Turntable Gear Replacement
你所需要的
  1. Audio-Technica LP60XBT Turntable Gear Replacement, Gear: 步骤 1 中的图像 1,2 Audio-Technica LP60XBT Turntable Gear Replacement, Gear: 步骤 1 中的图像 2,2
    • Remove the felt pad, and put it to the side.
  2. Audio-Technica LP60XBT Turntable Gear Replacement: 步骤 2 中的图像 1,1
    • Turn the platter so that the brass motor pulley can be seen through one of the two outer holes in the platter.
    • If the drive belt is hooked around the motor pulley, unhook it.
    • When reassembling to device, don't forget to hook the new drive belt to the motor pulley.
  3. Audio-Technica LP60XBT Turntable Gear Replacement: 步骤 3 中的图像 1,2 Audio-Technica LP60XBT Turntable Gear Replacement: 步骤 3 中的图像 2,2
    • Remove the platter by grasping the platter by its two inner holes and lifting it upwards.
    • If the drive belt is unhooked and the tone arm is safely to the side, don’t be afraid to use a small amount of force in lifting the platter if necessary.
  4. Audio-Technica LP60XBT Turntable Gear Replacement: 步骤 4 中的图像 1,1
    • Remove the four screws holding in the gears using a Phillips #0 screwdriver.
  5. Audio-Technica LP60XBT Turntable Gear Replacement: 步骤 5 中的图像 1,3 Audio-Technica LP60XBT Turntable Gear Replacement: 步骤 5 中的图像 2,3 Audio-Technica LP60XBT Turntable Gear Replacement: 步骤 5 中的图像 3,3
    • Remove the large white gear by pulling it upwards.
    • Remove the small white gear and base by pulling them upwards.
  6. Audio-Technica LP60XBT Turntable Gear Replacement: 步骤 6 中的图像 1,1
    • Insert the small replacement gear first, then the large replacement gear second.
    • When replacing the smaller gear and base, be sure to feed the black ground wire through the hole in the base.
结论
Devon Ferreira
于03/22/21注册
133 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 12
过去 30 天: 37
总计 1,473
