跳转到主内容
修复你的物品
维修的权力
商店
简介
This repair guide will help you with the following:
  • install the right headphone cable
  • fix sound in right ear
  1. Remove the ear pads by peeling them away from the grill.
    • Remove the ear pads by peeling them away from the grill.
    My jbl waerless headphone speaker changes how price
    Max Mad - 回复
    How to install the earpads
    rangaranju - 回复
  2. Remove all four 1cm screws on the inside of the headphone using a #1 Phillips head.
    • Remove all four 1cm screws on the inside of the headphone using a #1 Phillips head.
  3. Remove the speaker from the grill by pulling it out.
    • Remove the speaker from the grill by pulling it out.
    • Remove the speaker carefully so you do not rip the wires out.
  4. Remove the wires by de-soldering both the red and yellow wires using the soldering iron and desoldering wick. If you need assistance, reference 如何焊接和拆焊. The areas where you soldered will be hot so let the soldered joints cool for before handling again.
    • Remove the wires by de-soldering both the red and yellow wires using the soldering iron and desoldering wick. If you need assistance, reference 如何焊接和拆焊.
    • The areas where you soldered will be hot so let the soldered joints cool for before handling again.
  5. Connect the the new red and yellow wires by re-soldering the wires using the soldering iron. If you need assistance, reference 如何焊接和拆焊. The areas where you soldered will be hot so let the soldered joints cool for before handling again.
    • Connect the the new red and yellow wires by re-soldering the wires using the soldering iron. If you need assistance, reference 如何焊接和拆焊.
结论
2等其他人完成本指南。
Melanie Reis
于2013年01月11日注册
143 信誉积分
创作了5篇指南
团队
Cal Poly, Team 17-19, Forte Winter 2013 Cal Poly, Team 17-19, Forte Winter 2013 的会员
CPSU-FORTE-W13S17G19
6 名成员
创作了6篇指南
Where can i buy a replacement cable? Cant seem to find it anywhere.
Stefan Rasmussen - 回复
添加评论
浏览统计数据:
过去的24小时: 3
过去的7天: 14
过去的30天: 39
总计 3,505
