当前版本的文档还未经巡查,您可以查看最新的已查核版本。
你所需要的
3等其他人完成本指南。
2条评论
Not sure if it’s on purpose or not but on my A900Xs the cable is on the left headphone and so, the one on the right is the one with the tiny wire going through, I found that a 2 core wire is needed for this replacement, I only managed to find one that’s 1,4mm diameter and it seems to be a little thicker than what’s actually inside the headphones but I figured I’ll give it a try, anyways here’s the wire I found on AliExpress https://www.aliexpress.com/item/40004436...
Erez Dahan - 回复
