本指南有最近更改,您可查看未经巡查的最新版本。
简介
This repair guide will help you with the following:
- Install the left headphone cable
- Fix sound coming from the left headphone
你所需要的
Desolder the red, yellow, and blue wires using a soldering iron and desoldering wick. If you need assistance, reference 如何焊接和拆焊.
3等其他人完成本指南。
2条评论
Not sure if it’s on purpose or not but on my A900Xs the cable is on the left headphone and so, the one on the right is the one with the tiny wire going through, I found that a 2 core wire is needed for this replacement, I only managed to find one that’s 1,4mm diameter and it seems to be a little thicker than what’s actually inside the headphones but I figured I’ll give it a try, anyways here’s the wire I found on AliExpress https://www.aliexpress.com/item/40004436...
Erez Dahan - 回复
