跳转到主内容
Audio Technica ATH-AD500 Driver Replacement
你所需要的
  1. Audio Technica ATH-AD500 Driver Replacement, Speaker Assembly: 步骤 1 中的图像 1,1
    • Remove the ear pads by peeling them away from the grill.
  2. Audio Technica ATH-AD500 Driver Replacement: 步骤 2 中的图像 1,1
    • Remove all four 1cm screws on the inside of the headphone using a #1 Phillips head.
  3. Audio Technica ATH-AD500 Driver Replacement: 步骤 3 中的图像 1,1
    • Remove the speaker from the grill by pulling it out.
    • Remove the speaker carefully so you do not rip the wires out.
  4. Audio Technica ATH-AD500 Driver Replacement, Driver: 步骤 4 中的图像 1,1
    • With a #0 phillips head, unscrew the three, 1 cm screws which are holding the driver (red wafer) in its bracket.
  5. Audio Technica ATH-AD500 Driver Replacement: 步骤 5 中的图像 1,1
    • Pull the driver out of its bracket.
  6. Audio Technica ATH-AD500 Driver Replacement: 步骤 6 中的图像 1,2 Audio Technica ATH-AD500 Driver Replacement: 步骤 6 中的图像 2,2
    • Remove the two wires, red and yellow, by de-soldering them from the driver using a soldering iron and desoldering wick. Reference 如何焊接和拆焊.
    • The areas where you solder will be hot so wait until the solder joints are cool before handling the wires again.
  7. Audio Technica ATH-AD500 Driver Replacement: 步骤 7 中的图像 1,2 Audio Technica ATH-AD500 Driver Replacement: 步骤 7 中的图像 2,2
    • Connect the existing wires to the new driver by re-soldering the wires using the soldering iron.
    • Using the copper as a reference, re-solder the yellow wire to the top left solder joint and the red to the bottom left solder joint.
结论
2等其他人完成本指南。
Nick Levy
于01/13/13注册
177 声望
撰写一个指南
团队
Cal Poly, Team 17-19, Forte Winter 2013 Cal Poly, Team 17-19, Forte Winter 2013 的会员
CPSU-FORTE-W13S17G19
6 名成员
创作了17篇指南
2条评论
where can i buy a replacement driver?
acidxgangster - 回复
You can order parts directly from PARTS@ATUS.COM
Nick Levy -
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 44
总计 10,717
