简介
This guide will help your install a new driver.
  1. Remove the ear pads by peeling them away from the grill.
    • Remove the ear pads by peeling them away from the grill.
  2. Remove all four 1cm screws on the inside of the headphone using a #1 Phillips head.
    • Remove all four 1cm screws on the inside of the headphone using a #1 Phillips head.
  3. Remove the speaker from the grill by pulling it out.
    • Remove the speaker from the grill by pulling it out.
    • Remove the speaker carefully so you do not rip the wires out.
  4. 所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
    善于维修,即天赋异禀。
    与 #ImAGenius 分享您的维修故事
    我们都是天才
  5. With a #0 phillips head, unscrew the three, 1 cm screws which are holding the driver (red wafer) in its bracket.
    • With a #0 phillips head, unscrew the three, 1 cm screws which are holding the driver (red wafer) in its bracket.
  6. Pull the driver out of its bracket.
    • Pull the driver out of its bracket.
  7. Remove the two wires, red and yellow, by de-soldering them from the driver using a soldering iron and desoldering wick. Reference 如何焊接和脱焊. The areas where you solder will be hot so wait until the solder joints are cool before handling the wires again.
    • Remove the two wires, red and yellow, by de-soldering them from the driver using a soldering iron and desoldering wick. Reference 如何焊接和脱焊.
    • The areas where you solder will be hot so wait until the solder joints are cool before handling the wires again.
  8. Connect the existing wires to the new driver by re-soldering the wires using the soldering iron. Using the copper as a reference, re-solder the yellow wire to the top left solder joint and the red to the bottom left solder joint.
    • Connect the existing wires to the new driver by re-soldering the wires using the soldering iron.
    • Using the copper as a reference, re-solder the yellow wire to the top left solder joint and the red to the bottom left solder joint.
结论
另外一个人完成了本指南。
Nick Levy
于2013年01月13日注册
112 信誉积分
撰写一个指南
团队
Cal Poly, Team 17-19, Forte Winter 2013 Cal Poly, Team 17-19, Forte Winter 2013 的会员
CPSU-FORTE-W13S17G19
6 名成员
创作了6篇指南
where can i buy a replacement driver?
acidxgangster - 回复
You can order parts directly from PARTS@ATUS.COM
Nick Levy -
浏览统计数据:
过去的24小时: 3
过去的7天: 21
过去的30天: 107
总计 6,277
