跳转到主内容
Audio Technica AT-LP60XUSB Turntable Belt Replacement
你所需要的
  1. Audio Technica AT-LP60XUSB Turntable Belt Replacement, Turntable Belt: 步骤 1 中的图像 1,1
    • Disconnect the power from the turntable.
    • Never work on the turntable while it’s plugged in.
  2. Audio Technica AT-LP60XUSB Turntable Belt Replacement: 步骤 2 中的图像 1,2 Audio Technica AT-LP60XUSB Turntable Belt Replacement: 步骤 2 中的图像 2,2
    • Remove the rubber slipmat from the turntable and place it to the side.
  3. Audio Technica AT-LP60XUSB Turntable Belt Replacement: 步骤 3 中的图像 1,2 Audio Technica AT-LP60XUSB Turntable Belt Replacement: 步骤 3 中的图像 2,2
    • Pull the metallic platter with the broken belt straight up to remove it.
    • Do not use excessive force when removing the platter, as it may cause damage to internal components.
  4. Audio Technica AT-LP60XUSB Turntable Belt Replacement: 步骤 4 中的图像 1,3 Audio Technica AT-LP60XUSB Turntable Belt Replacement: 步骤 4 中的图像 2,3 Audio Technica AT-LP60XUSB Turntable Belt Replacement: 步骤 4 中的图像 3,3
    • Flip the metallic cover upside down.
    • Remove the old belt.
    • Place the new belt around the circle on the bottom of the plate.
    • Ensure the belt lies flat and is not twisted or bunched up.
  5. Audio Technica AT-LP60XUSB Turntable Belt Replacement: 步骤 5 中的图像 1,3 Audio Technica AT-LP60XUSB Turntable Belt Replacement: 步骤 5 中的图像 2,3 Audio Technica AT-LP60XUSB Turntable Belt Replacement: 步骤 5 中的图像 3,3
    • Flip the metallic plate over and place it onto the turntable.
    • Align the hole in the center of the plate with the silver knob in the middle of the turntable.
    • Rotate the metal plate until the rectangular opening near its edge lines up with the gold knob in the top-left corner.
    • Use your fingers to pull the belt through the rectangular opening and loop it around the gold knob.
    • Be gentle while stretching the belt onto the pulley to avoid tearing or misalignment.
  6. Audio Technica AT-LP60XUSB Turntable Belt Replacement: 步骤 6 中的图像 1,1
    • Place the rubber slipmat back on top of the turntable.
    • Connect the power to the turntable.
    • Turn the metallic plate on the turntable to confirm that the belt is spinning properly.
终点
Kenny
于03/04/25注册
133 声望
撰写一个指南
团队
CSU Los Angeles, Team 3-4, Grodsky Spring 2025 CSU Los Angeles, Team 3-4, Grodsky Spring 2025 的会员
CSULA-GRODSKY-S25S3G4
2 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 22
总计 165
