跳转到主内容
Atmega328P Microcontroller Replacement for Arduino Board
你所需要的
  1. Atmega328P Microcontroller Replacement for Arduino Board, Atmega328P Microcontroller: 步骤 1 中的图像 1,1
    • Place the Arduino UNO R3 board on a flat clean surface.
  2. Atmega328P Microcontroller Replacement for Arduino Board: 步骤 2 中的图像 1,2 Atmega328P Microcontroller Replacement for Arduino Board: 步骤 2 中的图像 2,2
    • On the right side of board, position a nylon spudger in between the microcontroller and the dip socket, and gently lift upwards to pry it out.
    • The bottom of the microcontroller can be scratched if not done carefully. Do not use a metal tool for this step.
  3. Atmega328P Microcontroller Replacement for Arduino Board: 步骤 3 中的图像 1,2 Atmega328P Microcontroller Replacement for Arduino Board: 步骤 3 中的图像 2,2
    • Repeat the same process on the other side.
    • Lift both sides evenly to prevent any damage to the pins.
  4. Atmega328P Microcontroller Replacement for Arduino Board: 步骤 4 中的图像 1,3 Atmega328P Microcontroller Replacement for Arduino Board: 步骤 4 中的图像 2,3 Atmega328P Microcontroller Replacement for Arduino Board: 步骤 4 中的图像 3,3
    • Repeat steps 2 and 3 until the microcontroller is loose enough to remove out of the socket.
  5. Atmega328P Microcontroller Replacement for Arduino Board: 步骤 5 中的图像 1,1
    • Remove replacement microcontroller out of packaging.
  6. Atmega328P Microcontroller Replacement for Arduino Board: 步骤 6 中的图像 1,1
    • If needed, straighten the pins of the replacement microcontroller and place it directly over the dip socket.
    • Make sure the notch on the side of the microcontroller is facing the right, matching the white lines on the board.
  7. Atmega328P Microcontroller Replacement for Arduino Board: 步骤 7 中的图像 1,2 Atmega328P Microcontroller Replacement for Arduino Board: 步骤 7 中的图像 2,2
    • Gently press the microcontroller into the dip socket
结论
2等其他人完成本指南。
团队
UC Davis, Team 5-5, Morris Winter 2023 UC Davis, Team 5-5, Morris Winter 2023 的会员
UCD-MORRIS-W23S5G5
2 名成员
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 9
过去 30 天: 50
总计 984
