跳转到主内容
Atari Flashback 2 Reset and Select Button Replacement
你所需要的
  1. Atari Flashback 2 Reset and Select Button Replacement, Reset or Select Button: 步骤 1 中的图像 1,3 Atari Flashback 2 Reset and Select Button Replacement, Reset or Select Button: 步骤 1 中的图像 2,3 Atari Flashback 2 Reset and Select Button Replacement, Reset or Select Button: 步骤 1 中的图像 3,3
    • Using the screwdriver and the PH1 bit, unscrew the five 10.0 mm screws on the bottom of the console.
    • One screw is under the main sticker in the middle of the console.
  2. Atari Flashback 2 Reset and Select Button Replacement: 步骤 2 中的图像 1,3 Atari Flashback 2 Reset and Select Button Replacement: 步骤 2 中的图像 2,3 Atari Flashback 2 Reset and Select Button Replacement: 步骤 2 中的图像 3,3
    • Unscrew the six 9.0 mm Phillips #1 screws on the brown circuit board that correspond to the reset and select buttons.
    • Remove gently. The circuit board is connected by wire to the console. Removing the cable from the console case may allow more slack.
结论
Gabriel Robinson
于09/17/18注册
85 声望
撰写一个指南
团队
2指南评论
Good night! I have a flashback2 atari which burst the capacitor EC1, could you help me with its value? Thank you!
pradose - 回复
Hi pradose! We no longer have the device so it will not be possible for our team to walk you through anything beyond the guides we posted.
Daniel Hoffman - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 24
总计 1,015
