本指南有最近更改,您可查看未经巡查的最新版本。
简介
If the button on an Atari Flashback 2 joystick is sticking or broken, then it will need to be cleaned or replaced. This guide covers the steps necessary to disassemble the joystick in order to access the button to do so efficiently.
你所需要的
Using the screwdriver and the PH1 bit, unscrew the four 10.0 mm screws on the bottom of the joystick.
Remove the bottom panel from the joystick.
即将完成!
结论
