跳转到主内容
Atari Flashback 2 Joystick Button Replacement
你所需要的
  1. Atari Flashback 2 Joystick Button Replacement, Joystick Button: 步骤 1 中的图像 1,1
    • Using the screwdriver and the PH1 bit, unscrew the four 10.0 mm screws on the bottom of the joystick.
    • Remove the bottom panel from the joystick.
  2. Atari Flashback 2 Joystick Button Replacement: 步骤 2 中的图像 1,1
    • Unscrew the single 8.0 mm Phillips#1 screw holding the circuit board in place.
    • Remove the circuit board from the joystick housing.
  3. Atari Flashback 2 Joystick Button Replacement: 步骤 3 中的图像 1,1
    • Inspect the circuit board for dirt, corrosion or damage. If necessary, clean the indicated contact using a cotton swab.
  4. Atari Flashback 2 Joystick Button Replacement: 步骤 4 中的图像 1,1
    • Remove the button from the joystick housing. Check for dirt or debris that may obstruct its movement. If the button is broken, replace it.
结论
Daniel Hoffman
于09/17/18注册
209 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 7
总计 580
