跳转到主内容
Atari Flashback 2 Console Power Button Replacement
你所需要的
  1. Atari Flashback 2 Console Power Button Replacement, Console Power Button: 步骤 1 中的图像 1,3 Atari Flashback 2 Console Power Button Replacement, Console Power Button: 步骤 1 中的图像 2,3 Atari Flashback 2 Console Power Button Replacement, Console Power Button: 步骤 1 中的图像 3,3
    • Using the screwdriver and PH1 bit, unscrew the five 10.0 mm screws.
    • One is under the main sticker in the middle of the console.
  2. Atari Flashback 2 Console Power Button Replacement: 步骤 2 中的图像 1,3 Atari Flashback 2 Console Power Button Replacement: 步骤 2 中的图像 2,3 Atari Flashback 2 Console Power Button Replacement: 步骤 2 中的图像 3,3
    • Use a PH1 screwdriver to unscrew the two 9.0 mm screws on the circuit board that corresponds to the red power button.
    • Remove gently. The circuit board is connected by wire to the console. Removing the cable from the console case may allow more slack.
    • A spring may pop out.
结论
Faith Julian
于09/18/18注册
205 声望
创作了2篇指南
团队
一条评论
Hello. I just bought a used atari flashback 2 and when I turn it on it seems that the power button is a little tricky. I wiggle the button in and out and half way etc. then sometimes I can get it to turn on. Once on, the video 'pulses' on and off and a pulsing sound is noticeable. Is it just a faulty power button or is it something worse like a power regulator. I've taken it apart and all seems to be ok looking ie. no burnt fuses etc.  Can you help?  ~Brad Beachin~
bradbeachin - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 20
总计 792
