跳转到主内容
Atari 5200 Number Pad Cleaning or Replacement
你所需要的
  1. Atari 5200 Number Pad Cleaning or Replacement, Open the controller: 步骤 1 中的图像 1,3 Atari 5200 Number Pad Cleaning or Replacement, Open the controller: 步骤 1 中的图像 2,3 Atari 5200 Number Pad Cleaning or Replacement, Open the controller: 步骤 1 中的图像 3,3
    • Turn the controller over.
    • Remove the three 6mm screws from the back.
    • Carefully slide and pull the two parts of the controller shell apart, exposing the innards.
    • Do not move the joystick when reassembling. This will break your alignment. The less the joystick is moved, the easier it will be to realign the joystick.
  2. Atari 5200 Number Pad Cleaning or Replacement, Cleaning/Reseating (number pad front and back): 步骤 2 中的图像 1,3 Atari 5200 Number Pad Cleaning or Replacement, Cleaning/Reseating (number pad front and back): 步骤 2 中的图像 2,3 Atari 5200 Number Pad Cleaning or Replacement, Cleaning/Reseating (number pad front and back): 步骤 2 中的图像 3,3
    • Take out the rubber button module of the number pad.
    • Blow out dust on the number pad sensors with compressed air.
    • Wipe the sensors clean with a cloth dabbed with alcohol.
  3. Atari 5200 Number Pad Cleaning or Replacement, Reassembly Part 1: 步骤 3 中的图像 1,2 Atari 5200 Number Pad Cleaning or Replacement, Reassembly Part 1: 步骤 3 中的图像 2,2
    • Use a spudger to remove the top frame.
    • Take off the plate.
    • Remove the rubber buttons.
  4. Atari 5200 Number Pad Cleaning or Replacement, Reassembly Part 2: 步骤 4 中的图像 1,2 Atari 5200 Number Pad Cleaning or Replacement, Reassembly Part 2: 步骤 4 中的图像 2,2
    • Pull the circuit strip through the new space.
    • Realign the top and bottom of the controller.
  5. Atari 5200 Number Pad Cleaning or Replacement, Reassembly Part 3: 步骤 5 中的图像 1,3 Atari 5200 Number Pad Cleaning or Replacement, Reassembly Part 3: 步骤 5 中的图像 2,3 Atari 5200 Number Pad Cleaning or Replacement, Reassembly Part 3: 步骤 5 中的图像 3,3
    • Return the buttons to the top of the controller.
    • Snap the frame back into place.
    • Screw the screws back into place.
结论
另外一个人完成了本指南。
Alan Abelson
于09/26/14注册
233 声望
创作了5篇指南
团队
USF Tampa, Team 13-1, Staggers Fall 2014 USF Tampa, Team 13-1, Staggers Fall 2014 的会员
USFT-STAGGERS-F14S13G1
5 名成员
创作了17篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 600
