跳转到主内容
Atari 5200 Joystick Repair
你所需要的
  1. Atari 5200 Joystick Repair, Opening the Controller: 步骤 1 中的图像 1,3 Atari 5200 Joystick Repair, Opening the Controller: 步骤 1 中的图像 2,3 Atari 5200 Joystick Repair, Opening the Controller: 步骤 1 中的图像 3,3
    • Turn the controller over, exposing the three screws on the back. Use a 6mm screwdriver to remove these screws.
    • Carefully slide and pull the two parts of the controller shell apart, exposing the innards.
  2. Atari 5200 Joystick Repair, Locating the Knobs and Pots: 步骤 2 中的图像 1,1
    • Find the knobs (closest to the joystick and circled in red).
    • Locate the pots (closest to the circuitry and circled in orange). Keep track of these.
    • Align the joystick's metal bar into its cup.
    • Don't move any of the button circuitry, especially those of the START/PAUSE/RESET buttons.
  3. Atari 5200 Joystick Repair, Reassembly Part 1: 步骤 3 中的图像 1,1
    • Use a spudger to remove the top frame.
    • Take off the plate.
    • Remove the rubber buttons.
  4. Atari 5200 Joystick Repair, Reassembly Part 2: 步骤 4 中的图像 1,2 Atari 5200 Joystick Repair, Reassembly Part 2: 步骤 4 中的图像 2,2
    • Realign the top and bottom of the controller.
    • Pull the circuit strip through the new space.
  5. Atari 5200 Joystick Repair, Reassembly Part 3: 步骤 5 中的图像 1,3 Atari 5200 Joystick Repair, Reassembly Part 3: 步骤 5 中的图像 2,3 Atari 5200 Joystick Repair, Reassembly Part 3: 步骤 5 中的图像 3,3
    • Return the start buttons to the top of the controller
    • Snap the frame back into place
    • Screw in the three screws on the back.
终点
4等其他人完成本指南。
Alan Abelson
于09/26/14注册
233 声望
创作了5篇指南
团队
USF Tampa, Team 13-1, Staggers Fall 2014 USF Tampa, Team 13-1, Staggers Fall 2014 的会员
USFT-STAGGERS-F14S13G1
5 名成员
创作了17篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 29
总计 3,851
