跳转到主内容
Atari 5200 Entertainment System Power Button Replacement
你所需要的
  1. Atari 5200 Entertainment System Power Button Replacement, Entertainment System Power Button: 步骤 1 中的图像 1,1
    • Gently flip the Atari Entertainment System over. You'll see 7 screws holding the system together. Use a philips head screw driver to remove all seven screws.
    • Pictured above is the Atari 5200 upside down. The orange edited circles over all 7 screws.
  2. Atari 5200 Entertainment System Power Button Replacement: 步骤 2 中的图像 1,1
    • Gently flip the Atari Entertainment System over to the front side. Remove the top.
  3. Atari 5200 Entertainment System Power Button Replacement: 步骤 3 中的图像 1,3 Atari 5200 Entertainment System Power Button Replacement: 步骤 3 中的图像 2,3 Atari 5200 Entertainment System Power Button Replacement: 步骤 3 中的图像 3,3
    • There are orange objects on the side of the system's top, pinch them.
    • If the triangles cannot be gripped, push the power button on the opposite side. This will lift the triangle to give access to easier grip.
  4. Atari 5200 Entertainment System Power Button Replacement: 步骤 4 中的图像 1,3 Atari 5200 Entertainment System Power Button Replacement: 步骤 4 中的图像 2,3 Atari 5200 Entertainment System Power Button Replacement: 步骤 4 中的图像 3,3
    • The Power button can now be removed/clean/replaced.
    • Be sure to keep an eye on the spring.
结论
2等其他人完成本指南。
Alan Abelson
于09/26/14注册
233 声望
创作了5篇指南
团队
USF Tampa, Team 13-1, Staggers Fall 2014 USF Tampa, Team 13-1, Staggers Fall 2014 的会员
USFT-STAGGERS-F14S13G1
5 名成员
创作了17篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 14
总计 1,532
