跳转到主内容
Asus Zenfone 4 Max SIM Card Replacement
你所需要的
  1. Asus Zenfone 4 Max SIM Card Replacement, SIM Card: 步骤 1 中的图像 1,1
    • Locate the SIM tray on the left edge of the phone.
    • There is a small hole on the outside of the SIM tray that will be used for opening the tray.
  2. Asus Zenfone 4 Max SIM Card Replacement: 步骤 2 中的图像 1,2 Asus Zenfone 4 Max SIM Card Replacement: 步骤 2 中的图像 2,2
    • Insert a SIM card eject tool into the hole.
    • Press until the SIM tray pops out slightly from the phone.
    • Be careful not to force any object to fit into the tray's opening hole. The object should be thin enough to fit directly into the hole.
  3. Asus Zenfone 4 Max SIM Card Replacement: 步骤 3 中的图像 1,2 Asus Zenfone 4 Max SIM Card Replacement: 步骤 3 中的图像 2,2
    • Once the SIM tray has been opened, gently pull the tray completely out of the phone.
    • Lift the old SIM card out of the tray with your fingers or flip the tray upside down to make the card fall out.
  4. Asus Zenfone 4 Max SIM Card Replacement: 步骤 4 中的图像 1,1
    • Finally, replace the old card with the new SIM card and close the SIM tray.
结论
To reassemble your device, place the SIM tray back into the tray slot
Maegan West
于10/02/18注册
839 声望
创作了4篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 25
总计 2,079
