跳转到主内容
Asus Zenfone 4 Max Charging Port Replacement
你所需要的
  1. Asus Zenfone 4 Max Charging Port Replacement, Battery: 步骤 1 中的图像 1,2 Asus Zenfone 4 Max Charging Port Replacement, Battery: 步骤 1 中的图像 2,2
    • Using a removable head screwdriver and a T3 bit, begin by removing the two screws located on either side of the charging port.
  2. Asus Zenfone 4 Max Charging Port Replacement: 步骤 2 中的图像 1,1
    • Gently wedge the opening tool between the phone and the back casing.
    • Move the opening tool up and down to pry the back off of the device.
  3. Asus Zenfone 4 Max Charging Port Replacement: 步骤 3 中的图像 1,3 Asus Zenfone 4 Max Charging Port Replacement: 步骤 3 中的图像 2,3 Asus Zenfone 4 Max Charging Port Replacement: 步骤 3 中的图像 3,3
    • Once the back has been removed, you will need to unscrew the four screws on the bottom panel with an AT3 bit.
  4. Asus Zenfone 4 Max Charging Port Replacement: 步骤 4 中的图像 1,1
    • Remove the bottom panel.
  5. Asus Zenfone 4 Max Charging Port Replacement: 步骤 5 中的图像 1,2 Asus Zenfone 4 Max Charging Port Replacement: 步骤 5 中的图像 2,2
    • Wedge an opening tool between the battery and phone.
    • Gently pry the battery out of the device.
    • You can move the opening on either side of the battery as well as the bottom to aid in removal.
  6. Asus Zenfone 4 Max Charging Port Replacement: 步骤 6 中的图像 1,1
    • Remove the battery and replace it with the new battery.
  7. Asus Zenfone 4 Max Charging Port Replacement, Charging Port: 步骤 7 中的图像 1,3 Asus Zenfone 4 Max Charging Port Replacement, Charging Port: 步骤 7 中的图像 2,3 Asus Zenfone 4 Max Charging Port Replacement, Charging Port: 步骤 7 中的图像 3,3
    • Once the battery has been removed, gently wedge the metal spudger beneath the green panel.
    • Lift the panel along with the charging port out the device and replace with the new charging port.
结论
3等其他人完成本指南。
Maegan West
于10/02/18注册
839 声望
创作了4篇指南
团队
2条评论
repair microfone asus zenfone 4 selfie pro please
John Wesley - 回复
I have managed to replace the charging port but now it shows Charging Port Temperatures Abnormalities Reminder which is loud and annoying to see every time. I also see that one of my sensors in the cpu-z program (thermal sensor pa_therm0) hitting a constant 75-84 degree centigrade and another sensor (chg_temp) hitting 65 constantly. Any help in regards to this manner?
Max Orwell - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 24
总计 3,199
