跳转到主内容
Asus Zenbook UX32VD Battery Replacement
你所需要的
  1. Asus Zenbook UX32VD Battery Replacement, Bottom Panel: 步骤 1 中的图像 1,3 Asus Zenbook UX32VD Battery Replacement, Bottom Panel: 步骤 1 中的图像 2,3 Asus Zenbook UX32VD Battery Replacement, Bottom Panel: 步骤 1 中的图像 3,3
    在这个步骤中使用的工具:
    T5 Torx Screwdriver
    $9.99
    购买
  2. Asus Zenbook UX32VD Battery Replacement: 步骤 2 中的图像 1,3 Asus Zenbook UX32VD Battery Replacement: 步骤 2 中的图像 2,3 Asus Zenbook UX32VD Battery Replacement: 步骤 2 中的图像 3,3
    • Use a plastic opening tool to pry along the perimeter of the bottom panel until it can be easily removed.
    • Remove the bottom panel from the body of the laptop.
    • Set aside the bottom panel.
  3. Asus Zenbook UX32VD Battery Replacement, Battery: 步骤 3 中的图像 1,2 Asus Zenbook UX32VD Battery Replacement, Battery: 步骤 3 中的图像 2,2
    • Remove the eight 3 mm Phillips #0 screws on the bottom panel.
  4. Asus Zenbook UX32VD Battery Replacement: 步骤 4 中的图像 1,2 Asus Zenbook UX32VD Battery Replacement: 步骤 4 中的图像 2,2
    • Pry up each side of the flat connectors by hand or with a plastic opening tool.
    • Lift the connector straight up from its socket.
  5. Asus Zenbook UX32VD Battery Replacement: 步骤 5 中的图像 1,3 Asus Zenbook UX32VD Battery Replacement: 步骤 5 中的图像 2,3 Asus Zenbook UX32VD Battery Replacement: 步骤 5 中的图像 3,3
    • Unplug the two bundled cable connectors on each side of the battery.
    • Pull the cable away from the connector in the same direction as the individual wires are running.
    • Pull evenly on the full width of the cable so that no individual wires are overly strained.
  6. Asus Zenbook UX32VD Battery Replacement: 步骤 6 中的图像 1,1
    • Remove the battery completely.
结论
4等其他人完成本指南。
Jenny Nguy
于09/17/15注册
180 声望
撰写一个指南
团队
CSU Fullerton, Team 2-2, Bruce Fall 2015 CSU Fullerton, Team 2-2, Bruce Fall 2015 的会员
CSUF-BRUCE-F15S2G2
4 名成员
创作了6篇指南
5条评论
what is the color code of the battery wiring? especially for the white and yellow
Asim Ahmed - 回复
Will this method also apply to ASUS Zenbook UX430UQ ?
Kurt Scheel - 回复
Is this the same method for ASUS Zenbook UX430UQ-GV050T ?
Kurt Scheel - 回复
this is probably odd, but can someone recommend me battery and speakers?
I did small research, have not found any speakers and found a few options with battery, but all of them looks suspicious, some comments like - dead after 1 year and etc...
Regards
Nikolay Em - 回复
Why would you replace the speakers? I don't ever understand, why would you unplug the speakers (as it's done in these instructions)? They are just taped on side of the battery, once you lift up the battery a little bit, you can take the speakers off from the battery pack and leave them on their place while replacing the battery.
Touko Korpela - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 28
总计 17,786
