跳转到主内容
Asus Zenbook UX32VD HD Web Camera Replacement
你所需要的
  1. Asus Zenbook UX32VD  HD Web Camera Replacement, HD Web Camera: 步骤 1 中的图像 1,1
    • Heat the adhesive behind the screen frame with a hair dryer or a heat gun.
    • Use low heat with the heat gun. Over heating could damage delicate electronic components.
  2. Asus Zenbook UX32VD  HD Web Camera Replacement: 步骤 2 中的图像 1,3 Asus Zenbook UX32VD  HD Web Camera Replacement: 步骤 2 中的图像 2,3 Asus Zenbook UX32VD  HD Web Camera Replacement: 步骤 2 中的图像 3,3
    在这个步骤中使用的工具:
    Metal Spudger Set
    $7.99
    购买
    • Insert a spudger between the display screen frame and the back screen panel.
    • Pry the display screen frame away from the back screen panel.
    • Continue to heat and remove the display screen frame along the whole perimeter.
  3. Asus Zenbook UX32VD  HD Web Camera Replacement: 步骤 3 中的图像 1,3 Asus Zenbook UX32VD  HD Web Camera Replacement: 步骤 3 中的图像 2,3 Asus Zenbook UX32VD  HD Web Camera Replacement: 步骤 3 中的图像 3,3
    • Remove display screen frame completely before adhesive cools and hardens.
  4. Asus Zenbook UX32VD  HD Web Camera Replacement: 步骤 4 中的图像 1,2 Asus Zenbook UX32VD  HD Web Camera Replacement: 步骤 4 中的图像 2,2
    • Unplug the bundled cable connector.
    • Pull the cable away from the connector in the same direction as the individual wires are running.
    • Pull evenly on the full width of the cable so that no individual wires are overly strained.
  5. Asus Zenbook UX32VD  HD Web Camera Replacement: 步骤 5 中的图像 1,3 Asus Zenbook UX32VD  HD Web Camera Replacement: 步骤 5 中的图像 2,3 Asus Zenbook UX32VD  HD Web Camera Replacement: 步骤 5 中的图像 3,3
    在这个步骤中使用的工具:
    Spudger
    $2.99
    购买
    • Pry the camera out from the two pins on the left and right of the camera with the tip of a spudger.
    • Remove the camera completely.
结论
Michael Remmel
于09/17/15注册
709 声望
创作了3篇指南
团队
CSU Fullerton, Team 2-2, Bruce Fall 2015 CSU Fullerton, Team 2-2, Bruce Fall 2015 的会员
CSUF-BRUCE-F15S2G2
4 名成员
创作了6篇指南
2条评论
what type/model/code for its replacement camera ? so i cant find it in part store...
tukangsedot - 回复
Thank you for the demo. It appears to be easy to replace the camera per your instructions. Kind regards. Mehran Gerami
Mehran Gerami - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 7
总计 1,865
