跳转到主内容
Asus Zenbook UX31E SSD Replacement
你所需要的
  1. Asus Zenbook UX31E SSD Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Using a T4 Torx screwdriver, remove the ten screws at the marked locations.
    • Place the screws into a container as to not lose them.
  2. Asus Zenbook UX31E SSD Replacement: 步骤 2 中的图像 1,1
    • Carefully slide your iFixit Opening Tool between the back panel.
    • Lift the back plate of your ASUS ZenBook UX31E, and place it to the side.
  3. Asus Zenbook UX31E SSD Replacement, SSD: 步骤 3 中的图像 1,1
    • Attach your Anti-Static Wrist Wrap to something metal as to not shock your system.
    • Peel back the warranty sticker to reveal the screw under it.
    • Using your Phillips #00 Precision Screwdriver, unscrew the screw that you just revealed.
  4. Asus Zenbook UX31E SSD Replacement: 步骤 4 中的图像 1,2 Asus Zenbook UX31E SSD Replacement: 步骤 4 中的图像 2,2
    • Using your hand, pull the SSD out from its slot.
结论
7等其他人完成本指南。
Charles Jackson
于02/02/17注册
668 声望
创作了3篇指南
团队
UW Tacoma, Team 1-2, Rose Winter 2017 UW Tacoma, Team 1-2, Rose Winter 2017 的会员
UWT-ROSE-W17S1G2
4 名成员
创作了9篇指南
一条评论
Vorrei fare una precisazione, l’SSD che monta questo laptop ha un attacco XM11, oramai non si usa più, pertanto è vero che possiamo sostituirlo ma dobbiamo aver cura di prendere un SSD M2 (2280) e un adattatore, io ho trovato su Amazon questo https://www.amazon.it/gp/product/B00XJRQ...
e ho preso come SSD un Crucial MX500 CT1000MX500SSD4 SSD Interno, 1 TB, 3D NAND, SATA, M.2 (2280)
Davide Bortot - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 45
总计 12,235
