简介
Motherboards most commonly fail because of an electrical surge or because the computer was dropped. The tools needed for this replacement are listed in the prerequisite guides.
Use the plastic opening tool to pry open the back cover of the laptop.
Remove the bottom panel of the laptop.
Disconnect the battery from the motherboard by gently pulling up and down on the connector.
Remove the 7 screws holding the motherboard in the case with a Phillips #00 screwdriver.
Remove the press fit connector attaching the motherboard to the screen.
Remove the two cables that are still attached to the motherboard. You will need to use needle nose tweezers to remove these.
