简介
If your Asus Zenbook UX31E laptop has stiff or unresponsive keys, use this guide to replace the keyboard.
The keyboard inputs character data to the laptop through key presses called keystrokes. Faulty keys may cause unregistered keystrokes with no input of character data. An on-screen keyboard available through Windows or an external USB keyboard may be used until internal keyboard issues are resolved.
Before starting a repair, make sure to power off your device completely and disconnect from any external power source.
你所需要的
Disconnect the battery from the motherboard by gently pulling up and down on the connector.
Use the plastic opening tool to pry open the back cover of the laptop.
Remove the bottom panel of the laptop.
Remove the 7 screws holding the motherboard in the case with a Phillips #00 screwdriver.
Remove the press fit connector attaching the motherboard to the screen.
Remove the two cables that are still attached to the motherboard. You will need to use needle nose tweezers to remove these.
2等其他人完成本指南。
