跳转到主内容
Asus Zenbook UX31E Fan Replacement
你所需要的
  1. Asus Zenbook UX31E Fan Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Using a T4 Torx screwdriver, remove the ten screws at the marked locations.
    • Place the screws into a container as to not lose them.
  2. Asus Zenbook UX31E Fan Replacement: 步骤 2 中的图像 1,1
    • Carefully slide your iFixit Opening Tool between the back panel.
    • Lift the back plate of your ASUS ZenBook UX31E, and place it to the side.
  3. Asus Zenbook UX31E Fan Replacement, Fan: 步骤 3 中的图像 1,2 Asus Zenbook UX31E Fan Replacement, Fan: 步骤 3 中的图像 2,2
    • Disconnect the ribbon between the IO and the motherboard on both sides.
  4. Asus Zenbook UX31E Fan Replacement: 步骤 4 中的图像 1,1
    • Disconnect the fan connector from the motherboard.
    • Pull up the clips on the ribbon connectors.
  5. Asus Zenbook UX31E Fan Replacement: 步骤 5 中的图像 1,2 Asus Zenbook UX31E Fan Replacement: 步骤 5 中的图像 2,2
    • Unscrew the two screws that are across each other.
  6. Asus Zenbook UX31E Fan Replacement: 步骤 6 中的图像 1,2 Asus Zenbook UX31E Fan Replacement: 步骤 6 中的图像 2,2
    • Using a plastic opening tool, lift the fan off of the laptop.
    • You can now use your hands and carefully pull the fan off the laptop.
结论
Sinh
于02/01/17注册
101 声望
撰写一个指南
团队
UW Tacoma, Team 1-2, Rose Winter 2017 UW Tacoma, Team 1-2, Rose Winter 2017 的会员
UWT-ROSE-W17S1G2
4 名成员
创作了9篇指南
一条评论
This guide does not explain how to replace the fan, but how to remove the fan.
How do you insert a new fan? (Specifically, how do you remove the fan from the component of which it is a part?)
Thank you in advance.
Albert - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 1,714
