跳转到主内容
Asus Zenbook UX31E Battery Replacement
你所需要的
  1. Asus Zenbook UX31E Battery Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Using a T4 Torx screwdriver, remove the ten screws at the marked locations.
    • Place the screws into a container as to not lose them.
    Can you tell me what size these screws are? I need to replace two.
    Elliot Lozano - 回复
    I don’t know, but you can search with product code: VISTORXUX31E
    See also: https://en.accessoires-asus.com/torx-scr...|l
    Davide Bortot -
  2. Asus Zenbook UX31E Battery Replacement: 步骤 2 中的图像 1,1
    • Carefully slide your iFixit Opening Tool between the back panel.
    • Lift the back plate of your ASUS ZenBook UX31E, and place it to the side.
  3. Asus Zenbook UX31E Battery Replacement, Battery: 步骤 3 中的图像 1,2 Asus Zenbook UX31E Battery Replacement, Battery: 步骤 3 中的图像 2,2
    • Disconnect the battery from the motherboard by gently pulling up and down on the connector.
  4. Asus Zenbook UX31E Battery Replacement: 步骤 4 中的图像 1,2 Asus Zenbook UX31E Battery Replacement: 步骤 4 中的图像 2,2
    • Using the Phillips #00 screwdriver, remove the screws from the middle and the two corners of the battery.
  5. Asus Zenbook UX31E Battery Replacement: 步骤 5 中的图像 1,2 Asus Zenbook UX31E Battery Replacement: 步骤 5 中的图像 2,2
    • Remove the battery. (Picture-1)
    • Picture of what the battery looks like.(Picture-2)
结论
5等其他人完成本指南。
Hersi Dahir
于02/02/17注册
203 声望
撰写一个指南
团队
UW Tacoma, Team 1-2, Rose Winter 2017 UW Tacoma, Team 1-2, Rose Winter 2017 的会员
UWT-ROSE-W17S1G2
4 名成员
创作了9篇指南
2条评论
Thanks for the easy to understand guide. Cheers!
Rahul Kashelani - 回复
Thanks for the guideline it easy to understand and easy to follow. Thanks again!
fiddyfadhlina - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 43
总计 7,786
