跳转到主内容
Asus Zenbook UX31A Wi-Fi Card Replacement
你所需要的
  1. Asus Zenbook UX31A Wi-Fi Card Replacement, Wi-Fi Card: 步骤 1 中的图像 1,2 Asus Zenbook UX31A Wi-Fi Card Replacement, Wi-Fi Card: 步骤 1 中的图像 2,2
    • Use a T6 screwdriver to remove the ten 6 mm case screws.
    • The two screws adjacent to the device serial number stamps are longer than the others. These two screws run about 11 mm long.
  2. Asus Zenbook UX31A Wi-Fi Card Replacement: 步骤 2 中的图像 1,2 Asus Zenbook UX31A Wi-Fi Card Replacement: 步骤 2 中的图像 2,2
    • Use a Phillips #00 screwdriver to remove the two 6 mm screws that secure the Wi-Fi card.
    • Wires are loose and easy to disconnect.
  3. Asus Zenbook UX31A Wi-Fi Card Replacement: 步骤 3 中的图像 1,1
    • Gently pull the the Wi-Fi card from the motherboard.
    • Disconnect the white and black wire by gently pulling each one up.
    • They can be a little tricky to put back on so take your time and be gentle.
结论
Sherwin
于03/22/22注册
209 声望
创作了2篇指南
团队
UMass Dartmouth, Team 7-1, Sinclaire Spring 2022 UMass Dartmouth, Team 7-1, Sinclaire Spring 2022 的会员
UMASSD-SINCLAIRE-S22S7G1
5 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 23
总计 339
