跳转到主内容
Asus Zenbook UX31A Fan Replacement
你所需要的
  1. Asus Zenbook UX31A Fan Replacement, Battery: 步骤 1 中的图像 1,2 Asus Zenbook UX31A Fan Replacement, Battery: 步骤 1 中的图像 2,2
    • Use a T6 screwdriver to remove the ten 6 mm case screws.
    • The two screws adjacent to the device serial number stamps are longer than the others. These two screws run about 11 mm long.
    • Remove the back cover from the laptop.
    • DO NOT BEND OR PUNCTURE THE BATTERY: Puncturing the battery can result in injury since the battery can catch fire or explode when exposed directly to oxygen
  2. Asus Zenbook UX31A Fan Replacement: 步骤 2 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove the three 7 mm screws that secure the battery.
  3. Asus Zenbook UX31A Fan Replacement: 步骤 3 中的图像 1,1
    • Unplug the bundled battery connector from the motherboard by gently pulling the cable up.
    • Make sure you pull the connector directly upwards or you could damage the connector
  4. Asus Zenbook UX31A Fan Replacement: 步骤 4 中的图像 1,1
    • Remove the battery from the laptop by lifting it up and out.
  5. Asus Zenbook UX31A Fan Replacement, Fan: 步骤 5 中的图像 1,2 Asus Zenbook UX31A Fan Replacement, Fan: 步骤 5 中的图像 2,2
    • Unclip both ZIF connector tabs by lifting the black tab up and away from the connector.
    • Remove the bridge connector.
  6. Asus Zenbook UX31A Fan Replacement: 步骤 6 中的图像 1,3 Asus Zenbook UX31A Fan Replacement: 步骤 6 中的图像 2,3 Asus Zenbook UX31A Fan Replacement: 步骤 6 中的图像 3,3
    • Use a Phillips #00 screwdriver to remove all seven 6 mm screws that secure the fan and heatsink.
  7. Asus Zenbook UX31A Fan Replacement: 步骤 7 中的图像 1,2 Asus Zenbook UX31A Fan Replacement: 步骤 7 中的图像 2,2
    • Disconnect the fan connector by puling on it horizontally until it disconnects.
    • Remove the fan.
结论
Brendan Walsh
于03/22/22注册
227 声望
创作了2篇指南
团队
UMass Dartmouth, Team 7-1, Sinclaire Spring 2022 UMass Dartmouth, Team 7-1, Sinclaire Spring 2022 的会员
UMASSD-SINCLAIRE-S22S7G1
5 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 24
总计 460
