跳转到主内容
Asus Zenbook UX303L Speaker Replacement
你所需要的
  1. Asus Zenbook UX303L Speaker Replacement, Speaker: 步骤 1 中的图像 1,1
    • Remove the eight 3mm screws using the T5 Torx Screwdriver.
    • Remove the 8mm screw using the T5 Torx Screwdriver.
  2. Asus Zenbook UX303L Speaker Replacement: 步骤 2 中的图像 1,1
    • Carefully remove the back plate from the laptop and located the battery and speakers towards the top.
  3. Asus Zenbook UX303L Speaker Replacement: 步骤 3 中的图像 1,1
    • Remove the four 4mm screws using the Phillips #0 screwdriver.
    • Remove the single 6mm screw using the Phillips #0 screwdriver.
  4. Asus Zenbook UX303L Speaker Replacement: 步骤 4 中的图像 1,1
    • Using your finger, gently lift upwards to remove the connection clip from the motherboard.
  5. Asus Zenbook UX303L Speaker Replacement: 步骤 5 中的图像 1,1
    • Gently pull the speaker connection clip outwards to remove it.
  6. Asus Zenbook UX303L Speaker Replacement: 步骤 6 中的图像 1,1
    • Carefully remove the speaker wires that are tucked underneath the tabs located at the edge of the laptop case.
    • Gently remove the battery from the laptop, the defective speakers should be glued with adhesive to the battery.
  7. Asus Zenbook UX303L Speaker Replacement: 步骤 7 中的图像 1,1
    • Carefully peel away the defective speakers from the battery.
结论
另外一个人完成了本指南。
Ryan Snow
于04/01/19注册
202 声望
撰写一个指南
团队
IUPUI, Team S1-G6, Harley Spring 2019 IUPUI, Team S1-G6, Harley Spring 2019 的会员
IUPUI-HARLEY-S19S1G6
3 名成员
创作了7篇指南
一条评论
Is the Asus UX303L same as U303L?
Michael Wolf - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 29
总计 1,795
