跳转到主内容
Asus Zenbook UX303L RAM Replacement
你所需要的
  1. Asus Zenbook UX303L RAM Replacement, RAM: 步骤 1 中的图像 1,1
    • Prior to installing RAM, it's good practice to ground yourself to avoid static discharge from damaging the internal components of the computer.
    • Avoid wearing static prone clothing or standing on carpet during the RAM replacement.
  2. Asus Zenbook UX303L RAM Replacement: 步骤 2 中的图像 1,2 Asus Zenbook UX303L RAM Replacement: 步骤 2 中的图像 2,2
    • Unscrew the eight 3 mm long screws on the bottom of the laptop along the parameter using a T5 Torx screwdriver.
    • Unscrew the one 8 mm long screw at the bottom of the laptop panel using a T5 Torx screwdriver.
    • Once all screws have been removed, carefully lift the bottom panel to reveal the RAM.
  3. Asus Zenbook UX303L RAM Replacement: 步骤 3 中的图像 1,3 Asus Zenbook UX303L RAM Replacement: 步骤 3 中的图像 2,3 Asus Zenbook UX303L RAM Replacement: 步骤 3 中的图像 3,3
    • Carefully pull apart the two clasps circled in red so that the RAM stick pops up.
    • Remove the stick of RAM from the SO-DIMM slot by gripping the edges of the RAM.
结论
另外一个人完成了本指南。
Evan Parker
于04/01/19注册
136 声望
撰写一个指南
团队
IUPUI, Team S1-G6, Harley Spring 2019 IUPUI, Team S1-G6, Harley Spring 2019 的会员
IUPUI-HARLEY-S19S1G6
3 名成员
创作了7篇指南
一条评论
This is incomplete. There are two screws more hidden behind the rubber support points (on the hinges side) of the computer.
And you need some adhesive to fix this rubber squares in place after you fix the lid in place.
Ochirosi Paul - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 43
总计 3,623
