跳转到主内容
Asus Zenbook UX303L Cooling Fan Replacement
你所需要的
  1. Asus Zenbook UX303L Cooling Fan Replacement, Cooling Fan: 步骤 1 中的图像 1,1
    • Make sure the device is turned off and disconnected from the battery charger.
  2. Asus Zenbook UX303L Cooling Fan Replacement: 步骤 2 中的图像 1,3 Asus Zenbook UX303L Cooling Fan Replacement: 步骤 2 中的图像 2,3 Asus Zenbook UX303L Cooling Fan Replacement: 步骤 2 中的图像 3,3
    • Remove the rubber pads closer to the air vents and remove the two screws using a P0 screwdriver.
    • Remove all the nine screws from the bottom of the device using a T5 screwdriver.
    • Carefully remove the bottom cover.
  3. Asus Zenbook UX303L Cooling Fan Replacement: 步骤 3 中的图像 1,2 Asus Zenbook UX303L Cooling Fan Replacement: 步骤 3 中的图像 2,2
    • Pull on the black flap to lift the LVDS cable next to the cooling fan.
  4. Asus Zenbook UX303L Cooling Fan Replacement: 步骤 4 中的图像 1,3 Asus Zenbook UX303L Cooling Fan Replacement: 步骤 4 中的图像 2,3 Asus Zenbook UX303L Cooling Fan Replacement: 步骤 4 中的图像 3,3
    • Remove the three screws from the hinges using a PH-1 screwdriver.
    • Open the device at a 90 degree angle to free the hinges.
  5. Asus Zenbook UX303L Cooling Fan Replacement: 步骤 5 中的图像 1,3 Asus Zenbook UX303L Cooling Fan Replacement: 步骤 5 中的图像 2,3 Asus Zenbook UX303L Cooling Fan Replacement: 步骤 5 中的图像 3,3
    • Remove the screws attached to the cooling fan with a PH-1 screwdriver.
    • Disconnect the wire attaching the cooling fan to the motherboard.
  6. Asus Zenbook UX303L Cooling Fan Replacement: 步骤 6 中的图像 1,2 Asus Zenbook UX303L Cooling Fan Replacement: 步骤 6 中的图像 2,2
    • Gently lift and slide the cooling fan out.
结论
4等其他人完成本指南。
团队
3条评论
After the 6 step Would i then just remove the dust on the cooling fan and reassemble after that? or replace the fan as a whole
Sean Gerald Wong - 回复
I wish you guys had included the part number for the cooling fan.
mhyson - 回复
I think that it is important to recommend to remove the battery first, otherwise there is a risk of short...
Don't ask me how I know... :-(
Nmariotti - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 30
总计 6,158
