跳转到主内容
Asus Zenbook UX303L Battery Replacement
你所需要的
  1. Asus Zenbook UX303L Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Ensure your device is OFF before performing this procedure.
    • Remove the eight 3 mm long screws using a T5 Torx Screwdriver.
    • Remove the single 8 mm long screw using a T5 Torx screwdriver.
  2. Asus Zenbook UX303L Battery Replacement: 步骤 2 中的图像 1,2 Asus Zenbook UX303L Battery Replacement: 步骤 2 中的图像 2,2
    • Lift and remove the back cover.
    • If your case does not easily come free, you may need to remove screws under the plastic feet on the bottom case.
  3. Asus Zenbook UX303L Battery Replacement: 步骤 3 中的图像 1,1
    • Use a Phillips #0 screwdriver to remove the four 4 mm screws from the sides of the battery.
    • Use a Phillips #0 screwdriver to remove the single 6 mm screw in the center of the battery.
  4. Asus Zenbook UX303L Battery Replacement: 步骤 4 中的图像 1,2 Asus Zenbook UX303L Battery Replacement: 步骤 4 中的图像 2,2
    • Lift the battery connector up out of its socket on the motherboard to disconnect it.
    • A plastic opening tool can help lift the connector out of its socket. Do not pry on the socket itself or you risk damaging the motherboard.
  5. Asus Zenbook UX303L Battery Replacement: 步骤 5 中的图像 1,1
    • Disconnect the speaker by carefully pulling the speaker cable away from its socket on the motherboard.
  6. Asus Zenbook UX303L Battery Replacement: 步骤 6 中的图像 1,1
    • Deroute the speaker cable from the clips so the battery can be fully removed.
  7. Asus Zenbook UX303L Battery Replacement: 步骤 7 中的图像 1,2 Asus Zenbook UX303L Battery Replacement: 步骤 7 中的图像 2,2
    • Lift up and remove the battery and speakers from the device.
  8. Asus Zenbook UX303L Battery Replacement: 步骤 8 中的图像 1,1
    • Remove the speakers from the old battery.
结论
3等其他人完成本指南。
Aashray Nagpal
于04/01/19注册
155 声望
撰写一个指南
团队
IUPUI, Team S1-G6, Harley Spring 2019 IUPUI, Team S1-G6, Harley Spring 2019 的会员
IUPUI-HARLEY-S19S1G6
3 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 31
过去 30 天: 150
总计 10,129
