简介
The Asus Zenbook UX21e has an extremely easy hard drive to replace. Initially, follow the battery replacement steps. Then proceed to unscrew the single screw holding down the SSD, then subsequently remove the SSD.
When removing the screw, try to remove the tape covering it.
你所需要的
Using a T4 Torx screwdriver, unscrew the ten screws lining the bottom cover. Then, proceed to remove the bottom cover by sliding it out parallel toward the back of the computer.
There are two length of screws. Eight screws are 3mm and two are 5mm. The two 5mm screws always go into the two center holes along the back edge.
Unscrew the single 3mm screw with a Phillips #1 screwdriver at the rightmost edge of the Hard Drive.
Remove the Hard Drive by sliding it parallel to the motherboard.
