跳转到主内容
Asus Zenbook UX21e Cooling System Replacement
你所需要的
  1. Asus Zenbook UX21e Cooling System Replacement, Battery: 步骤 1 中的图像 1,3 Asus Zenbook UX21e Cooling System Replacement, Battery: 步骤 1 中的图像 2,3 Asus Zenbook UX21e Cooling System Replacement, Battery: 步骤 1 中的图像 3,3
    • Using a T4 Torx screwdriver, unscrew the ten screws lining the bottom cover. Then, proceed to remove the bottom cover by sliding it out parallel toward the back of the computer.
    • There are two length of screws. Eight screws are 3mm and two are 5mm. The two 5mm screws always go into the two center holes along the back edge.
  2. Asus Zenbook UX21e Cooling System Replacement: 步骤 2 中的图像 1,3 Asus Zenbook UX21e Cooling System Replacement: 步骤 2 中的图像 2,3 Asus Zenbook UX21e Cooling System Replacement: 步骤 2 中的图像 3,3
    • Using an iFixit opening tool and your other hand, gently lift the connector up from the tape wrapped around the connector wires and pry the connector from the motherboard.
  3. Asus Zenbook UX21e Cooling System Replacement: 步骤 3 中的图像 1,1
    • Remove the battery by unscrewing the five 3mm screws using a Phillips #1 screwdriver.
    • One at each corner and one in the center.
  4. Asus Zenbook UX21e Cooling System Replacement: 步骤 4 中的图像 1,2 Asus Zenbook UX21e Cooling System Replacement: 步骤 4 中的图像 2,2
    • Lift the battery directly up and remove it from the device.
  5. Asus Zenbook UX21e Cooling System Replacement, Cooling System: 步骤 5 中的图像 1,3 Asus Zenbook UX21e Cooling System Replacement, Cooling System: 步骤 5 中的图像 2,3 Asus Zenbook UX21e Cooling System Replacement, Cooling System: 步骤 5 中的图像 3,3
    • Remove the plastic piece (labeled M3 10) sitting on top of the fan by lifting from one edge and peeling it over.
  6. Asus Zenbook UX21e Cooling System Replacement: 步骤 6 中的图像 1,2 Asus Zenbook UX21e Cooling System Replacement: 步骤 6 中的图像 2,2
    • Disconnect fan from motherboard by pulling the small white and blue connector from its socket.
  7. Asus Zenbook UX21e Cooling System Replacement: 步骤 7 中的图像 1,2 Asus Zenbook UX21e Cooling System Replacement: 步骤 7 中的图像 2,2
    • Remove the seven 3mm screws that hold the cooling system down using a Phillips #1 screwdriver.
    • Four are along the heat sink above the CPU, one is on the side of smaller heat sink to the left of the CPU heat sink. Two are along the edge of the fan.
    • Remove the cooling system from the device.
结论
To reassemble your device, follow these instructions in reverse order. Make sure to clean the CPU with a clean and dry cloth and compressed air. You must also squeeze new thermal paste onto the CPU before reassembling.
另外一个人完成了本指南。
Zachary Eslick
于04/23/18注册
756 声望
创作了5篇指南
团队
Cal Poly, Team S22-G1, Maness Spring 2018 Cal Poly, Team S22-G1, Maness Spring 2018 的会员
CPSU-MANESS-S18S22G1
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 9
总计 1,082
