简介
If the charging port of your Asus ZenFone 5 stops working, here are some steps to replace the charging port without puncturing the battery or otherwise damaging your device. The charging port is where you plug in the cable to charge your Asus ZenFone 5, and when it fails the device will have difficulty or be unable to charge.
你所需要的
Insert a SIM card removal tool or the end of a paperclip into the small hole on the lefthand side of the phone to release the SIM card.
Pull out the SIM card tray.
Use a halberd spudger to pry up the battery's press fit connector from the motherboard.
Gently pry the battery out of the case, taking care not to bend or puncture the battery.
