跳转到主内容
简介
Prerequisite Only
配件
没有特定配件。
  1. Use your fingernail to gently pry off the phone's back cover at the indicated location. While your fingernail is under the back cover slide your finger around the edges of the phone until the cover pops off. Use your fingernail to gently pry off the phone's back cover at the indicated location. While your fingernail is under the back cover slide your finger around the edges of the phone until the cover pops off.
    • Use your fingernail to gently pry off the phone's back cover at the indicated location. While your fingernail is under the back cover slide your finger around the edges of the phone until the cover pops off.
  2. Remove the thirteen black screws and the single silver screw from the back of the phone with a JIS size 00 screwdriver.
    • Remove the thirteen black screws and the single silver screw from the back of the phone with a JIS size 00 screwdriver.
    • The black screws are 2.8 mm in length.
    • The silver screw is 5.5 mm in length.
    • The black screw next to the camera and the flash is covered by a sticker. This screw can be easily removed as if there were no sticker on top of it. The point of the screwdriver should be able to pierce through the sticker easily.
  3. Use a plastic opening tool to remove the inner phone backing. The parts of the inner backing held down by two strips of double sided tape can be easily loosened by inserting the plastic opening tool underneath it and gently lifting it up.
    • Use a plastic opening tool to remove the inner phone backing.
    • The parts of the inner backing held down by two strips of double sided tape can be easily loosened by inserting the plastic opening tool underneath it and gently lifting it up.
  4. Note the position of the speaker unit so you can replace it in the correct place during reassembly.
    • Note the position of the speaker unit so you can replace it in the correct place during reassembly.
    • Take the speaker out of the back of the phone. It should come out easily as soon as the inner back is removed because nothing is holding it down in place anymore.
结论
40等其他人完成本指南。
Eduardo Nodarse
于2016年02月10日注册
4,755 信誉积分
创作了5篇指南
团队
USF Tampa, Team 2-5, Sullivan Spring 2016 USF Tampa, Team 2-5, Sullivan Spring 2016 的会员
USFT-SULLIVAN-S16S2G5
4 名成员
创作了16篇指南
添加评论
浏览统计数据:
过去的24小时: 8
过去的7天: 45
过去的30天: 192
总计 21,393
