跳转到主内容
Asus ZenBook UX303U Back Panel Replacement
你所需要的
  1. Asus ZenBook UX303U Back Panel Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Remove the two round rubber feet at the hinge-edge of the laptop.
    The process took me about 30 minutes. If I were to have to do it again then I could probably do it in 10 minutes now that I know what is involved!
    Jon Kerridge - 回复
  2. Asus ZenBook UX303U Back Panel Replacement: 步骤 2 中的图像 1,1
    • Remove the eleven 4 mm Phillips #00 screws from the back panel.
    These screws on other models are Torx T5 or T6, not Phillips
    Dylan Warburg - 回复
    T4 screws on all but the two under the rear rubber feet; those are Phillips PH0 (and my model had two square rubber feet).
    Gregg Stanley - 回复
  3. Asus ZenBook UX303U Back Panel Replacement: 步骤 3 中的图像 1,2 Asus ZenBook UX303U Back Panel Replacement: 步骤 3 中的图像 2,2
    • Using a plastic opening tool pry the back panel off of the laptop.
    I lift more than the last photo shows. Dark rubber with plots, visible on photo are blocking the opening.
    djibe - 回复
结论
2等其他人完成本指南。
Luis Perez
于02/14/18注册
598 声望
创作了2篇指南
团队
USF Tampa, Team S3-G5, Nance Spring 2018 USF Tampa, Team S3-G5, Nance Spring 2018 的会员
USFT-NANCE-S18S3G5
3 名成员
创作了9篇指南
一条评论
Some models may utilize Phillips #00 screws, but mine (and many others based on what I’ve now read) utilize Torx T5 screws around the edges of the panel.
Nick Brennan - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 13
总计 5,239
