跳转到主内容
Asus ZenBook Flip UX360C Speaker Replacement
你所需要的
  1. Asus ZenBook Flip UX360C Speaker Replacement, Rubber Feet: 步骤 1 中的图像 1,3 Asus ZenBook Flip UX360C Speaker Replacement, Rubber Feet: 步骤 1 中的图像 2,3 Asus ZenBook Flip UX360C Speaker Replacement, Rubber Feet: 步骤 1 中的图像 3,3
    • Turn laptop over.
    • Use the metal spudger to pry rubber feet off in the four corners of laptop.
  2. Asus ZenBook Flip UX360C Speaker Replacement, Speaker: 步骤 2 中的图像 1,1
    • Attach an ESD wristband to your wrist and clip the grounding clamp to a grounded metal object.
  3. Asus ZenBook Flip UX360C Speaker Replacement: 步骤 3 中的图像 1,1
    • Remove all eleven 5 mm, Phillips #1 screws on the back cover.
  4. Asus ZenBook Flip UX360C Speaker Replacement: 步骤 4 中的图像 1,1
    • Use a plastic opening tool to remove the keyboard panel.
  5. Asus ZenBook Flip UX360C Speaker Replacement: 步骤 5 中的图像 1,1
    • Use a plastic opening tool to disconnect the ZIF keyboard ribbon cable from the motherboard.
  6. Asus ZenBook Flip UX360C Speaker Replacement: 步骤 6 中的图像 1,3 Asus ZenBook Flip UX360C Speaker Replacement: 步骤 6 中的图像 2,3 Asus ZenBook Flip UX360C Speaker Replacement: 步骤 6 中的图像 3,3
    • Use nylon-tipped tweezeres to detach the battery connection.
  7. Asus ZenBook Flip UX360C Speaker Replacement: 步骤 7 中的图像 1,1
    • Remove all ten Phillips #1 battery retaining screws.
  8. Asus ZenBook Flip UX360C Speaker Replacement: 步骤 8 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Using tweezers, carefully remove the connector connecting the speakers to the motherboard.
  9. Asus ZenBook Flip UX360C Speaker Replacement: 步骤 9 中的图像 1,3 Asus ZenBook Flip UX360C Speaker Replacement: 步骤 9 中的图像 2,3 Asus ZenBook Flip UX360C Speaker Replacement: 步骤 9 中的图像 3,3
    • Use your fingers or another object to slightly raise the bottom edge of the battery. The battery does not need to be fully removed to replace the speakers.
    • Use a nylon spudger or an opening tool to carefully pry the speaker from the chassis.
    • The speaker is held down with a mild adhesive. Work your way around the border to fully remove the speaker.
  10. Asus ZenBook Flip UX360C Speaker Replacement: 步骤 10 中的图像 1,2 Asus ZenBook Flip UX360C Speaker Replacement: 步骤 10 中的图像 2,2
    • Use tweezers to carefully unseat the cable connecting the left and right speakers.
  11. Asus ZenBook Flip UX360C Speaker Replacement: 步骤 11 中的图像 1,3 Asus ZenBook Flip UX360C Speaker Replacement: 步骤 11 中的图像 2,3 Asus ZenBook Flip UX360C Speaker Replacement: 步骤 11 中的图像 3,3
结论
团队
IUPUI, Team 1-4, Harley Spring 2022 IUPUI, Team 1-4, Harley Spring 2022 的会员
IUPUI-HARLEY-S22S1G4
3 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 18
总计 521
