跳转到主内容
Asus ZenBook Flip UX360C Motherboard Replacement
你所需要的
  1. Asus ZenBook Flip UX360C Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,1
    • Remove all ten T5 screws on the back cover near the edges.
    • Remove two Phillips #1 screws located under the rubber feet near the screen.
  2. Asus ZenBook Flip UX360C Motherboard Replacement: 步骤 2 中的图像 1,3 Asus ZenBook Flip UX360C Motherboard Replacement: 步骤 2 中的图像 2,3 Asus ZenBook Flip UX360C Motherboard Replacement: 步骤 2 中的图像 3,3
    • Use a metal spudger to gently separate the keyboard from the computer case.
    • Do not completely remove the keyboard as there are two ribbon cables that connect the keyboard to the motherboard.
    • Lift the keyboard slightly, and use a plastic spudger to release the two ZIF connections to free each ribbon cable.
    • Remove the keyboard.
  3. Asus ZenBook Flip UX360C Motherboard Replacement: 步骤 3 中的图像 1,1
    • Use the Phillips #1 screwdriver to remove all 5 mm screws.
  4. Asus ZenBook Flip UX360C Motherboard Replacement: 步骤 4 中的图像 1,1
    • Use a plastic opening tool or nylon spudger to lift the monitor connections off of the main board.
  5. Asus ZenBook Flip UX360C Motherboard Replacement: 步骤 5 中的图像 1,2 Asus ZenBook Flip UX360C Motherboard Replacement: 步骤 5 中的图像 2,2
    • Clip off the battery from the main board.
    • Use of a metal spudger can cause damage to the device or harm to the user, especially near the battery! Use an ESD safe tool for this step instead.
  6. Asus ZenBook Flip UX360C Motherboard Replacement: 步骤 6 中的图像 1,2 Asus ZenBook Flip UX360C Motherboard Replacement: 步骤 6 中的图像 2,2
    • Remove the black foam above the screw on the I/O board.
    • Remove the 5 mm #1 Phillips head screw.
  7. Asus ZenBook Flip UX360C Motherboard Replacement: 步骤 7 中的图像 1,2 Asus ZenBook Flip UX360C Motherboard Replacement: 步骤 7 中的图像 2,2
    • Pull the I/O board away from the chip to detach it.
    • Remove the I/O board and main board.
结论
Jonathan Heintz
于02/27/19注册
145 声望
撰写一个指南
一条评论
where can i buy the motherboard?
Thevan - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 18
总计 2,978
