简介
This guide will teach you how to replace the Ethernet/LAN board to restore internet or device connectivity. No prior knowledge is required.
你所需要的
Use the plastic opening tool to pry off the black plastic strip at the bottom of the screen by wiggling the tool between the strip and the screen.
Run the opening tool slowly along the base of the screen, peeling the black strip back, until the opposite end of the screen is reached.
Place the computer on its back, facing up.
Wedge the plastic opening tool in between the screen and the bezel of the aluminum computer casing.
Move the tool along the entire edge of the screen with an up-and-down prying motion to loosen the screen from the casing. Do not lift the entire screen away from the computer yet.
Disconnect the ribbon cable from the side that has "MB" labeled on it by lifting up on the black locking flap and pulling the cable out of its terminal.
