跳转到主内容
Asus Z54C-JS31 WiFi Card Replacement
你所需要的
  1. Asus Z54C-JS31 WiFi Card Replacement, Battery: 步骤 1 中的图像 1,3 Asus Z54C-JS31 WiFi Card Replacement, Battery: 步骤 1 中的图像 2,3 Asus Z54C-JS31 WiFi Card Replacement, Battery: 步骤 1 中的图像 3,3
    • Turn the laptop upside down so that the underside is facing up and locate the two switches that are on each side of the battery.
    • Slide the switch on the top right corner to the right.
    • Slide and hold the switch on the top left corner to the left and carefully remove the battery.
  2. Asus Z54C-JS31 WiFi Card Replacement, HDD/RAM Cover Panel: 步骤 2 中的图像 1,2 Asus Z54C-JS31 WiFi Card Replacement, HDD/RAM Cover Panel: 步骤 2 中的图像 2,2
    • Use a Phillips #000 screwdriver to remove the two 9mm screws from the HDD/RAM cover panel.
  3. Asus Z54C-JS31 WiFi Card Replacement: 步骤 3 中的图像 1,2 Asus Z54C-JS31 WiFi Card Replacement: 步骤 3 中的图像 2,2
    • Slide the back panel off by placing a hand on each corner and pulling the panel towards you.
  4. Asus Z54C-JS31 WiFi Card Replacement, WiFi Card: 步骤 4 中的图像 1,3 Asus Z54C-JS31 WiFi Card Replacement, WiFi Card: 步骤 4 中的图像 2,3 Asus Z54C-JS31 WiFi Card Replacement, WiFi Card: 步骤 4 中的图像 3,3
    • Disconnect both the black and white coaxial connectors from the WiFi card by pulling up on the gold colored piece.
  5. Asus Z54C-JS31 WiFi Card Replacement: 步骤 5 中的图像 1,3 Asus Z54C-JS31 WiFi Card Replacement: 步骤 5 中的图像 2,3 Asus Z54C-JS31 WiFi Card Replacement: 步骤 5 中的图像 3,3
    • Remove the 3mm screw from the top right corner of the WiFi card using a Phillips #0 screwdriver.
    • The WiFi card will pop up. Grasp it and pull it out of its slot.
结论
Mark DeSimone
于10/19/17注册
801 声望
创作了8篇指南
团队
UMass Dartmouth, Team S3-G1, Bailey Fall 2017 UMass Dartmouth, Team S3-G1, Bailey Fall 2017 的会员
UMASSD-BAILEY-F17S3G1
2 名成员
创作了8篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 14
总计 1,673
