跳转到主内容
Asus Z54C-JS31 Motherboard Replacement
你所需要的
  1. Asus Z54C-JS31 Motherboard Replacement, Battery: 步骤 1 中的图像 1,3 Asus Z54C-JS31 Motherboard Replacement, Battery: 步骤 1 中的图像 2,3 Asus Z54C-JS31 Motherboard Replacement, Battery: 步骤 1 中的图像 3,3
    • Turn the laptop upside down so that the underside is facing up and locate the two switches that are on each side of the battery.
    • Slide the switch on the top right corner to the right.
    • Slide and hold the switch on the top left corner to the left and carefully remove the battery.
  2. Asus Z54C-JS31 Motherboard Replacement, HDD/RAM Cover Panel: 步骤 2 中的图像 1,2 Asus Z54C-JS31 Motherboard Replacement, HDD/RAM Cover Panel: 步骤 2 中的图像 2,2
    • Use a Phillips #000 screwdriver to remove the two 9mm screws from the HDD/RAM cover panel.
  3. Asus Z54C-JS31 Motherboard Replacement: 步骤 3 中的图像 1,2 Asus Z54C-JS31 Motherboard Replacement: 步骤 3 中的图像 2,2
    • Slide the back panel off by placing a hand on each corner and pulling the panel towards you.
  4. Asus Z54C-JS31 Motherboard Replacement, Hard Drive: 步骤 4 中的图像 1,2 Asus Z54C-JS31 Motherboard Replacement, Hard Drive: 步骤 4 中的图像 2,2
    • Remove the four 9mm screws holding the hard drive in place.
  5. Asus Z54C-JS31 Motherboard Replacement: 步骤 5 中的图像 1,3 Asus Z54C-JS31 Motherboard Replacement: 步骤 5 中的图像 2,3 Asus Z54C-JS31 Motherboard Replacement: 步骤 5 中的图像 3,3
    • Slide the hard drive to the left to disconnect it.
    • Then pull on the black tab to lift the hard drive out of the laptop.
  6. Asus Z54C-JS31 Motherboard Replacement, WiFi Card: 步骤 6 中的图像 1,3 Asus Z54C-JS31 Motherboard Replacement, WiFi Card: 步骤 6 中的图像 2,3 Asus Z54C-JS31 Motherboard Replacement, WiFi Card: 步骤 6 中的图像 3,3
    • Disconnect both the black and white coaxial connectors from the WiFi card by pulling up on the gold colored piece.
  7. Asus Z54C-JS31 Motherboard Replacement: 步骤 7 中的图像 1,3 Asus Z54C-JS31 Motherboard Replacement: 步骤 7 中的图像 2,3 Asus Z54C-JS31 Motherboard Replacement: 步骤 7 中的图像 3,3
    • Remove the 3mm screw from the top right corner of the WiFi card using a Phillips #0 screwdriver.
    • The WiFi card will pop up. Grasp it and pull it out of its slot.
  8. Asus Z54C-JS31 Motherboard Replacement, Keyboard: 步骤 8 中的图像 1,2 Asus Z54C-JS31 Motherboard Replacement, Keyboard: 步骤 8 中的图像 2,2
    • Turn the laptop to its normal position and open the display to show the keyboard.
    • Gently push back the five tabs holding the keyboard down using the plastic opening tool.
  9. Asus Z54C-JS31 Motherboard Replacement: 步骤 9 中的图像 1,3 Asus Z54C-JS31 Motherboard Replacement: 步骤 9 中的图像 2,3 Asus Z54C-JS31 Motherboard Replacement: 步骤 9 中的图像 3,3
    • Once the keyboard is free, disconnect the ribbon cable from the zero insertion force (ZIF) connector by flipping up the locking flap and pulling the cable out.
  10. Asus Z54C-JS31 Motherboard Replacement, Optical Disc Drive: 步骤 10 中的图像 1,3 Asus Z54C-JS31 Motherboard Replacement, Optical Disc Drive: 步骤 10 中的图像 2,3 Asus Z54C-JS31 Motherboard Replacement, Optical Disc Drive: 步骤 10 中的图像 3,3
    • Remove the 3mm screw with a Phillips #000 screwdriver.
    • Slide out the optical disc drive by pulling it away from the laptop.
  11. Asus Z54C-JS31 Motherboard Replacement, Motherboard: 步骤 11 中的图像 1,3 Asus Z54C-JS31 Motherboard Replacement, Motherboard: 步骤 11 中的图像 2,3 Asus Z54C-JS31 Motherboard Replacement, Motherboard: 步骤 11 中的图像 3,3
    • Turn the laptop over so that the back side is facing up.
    • Remove eight 9mm screws from the back of the laptop.
    • Remove two 6mm screws near the battery.
    • Remove two 3mm screws from the optical drive slot.
  12. Asus Z54C-JS31 Motherboard Replacement: 步骤 12 中的图像 1,2 Asus Z54C-JS31 Motherboard Replacement: 步骤 12 中的图像 2,2
    • Disconnect the two ribbons cables from the zero insertion force connectors by flipping up the small locking flap and pulling them gently out of the connectors.
  13. Asus Z54C-JS31 Motherboard Replacement: 步骤 13 中的图像 1,2 Asus Z54C-JS31 Motherboard Replacement: 步骤 13 中的图像 2,2
    • Use the plastic opening tool to pop off the plastic layer by sticking it in between the two parts and sliding it around the whole laptop.
    • Lift off the top plastic layer.
  14. Asus Z54C-JS31 Motherboard Replacement: 步骤 14 中的图像 1,2 Asus Z54C-JS31 Motherboard Replacement: 步骤 14 中的图像 2,2
    • Disconnect the two ribbon cables from the no-fuss ribbon cable connectors attached to the motherboard by pulling the cable straight out of the connector.
    • Disconnect the ribbon cable from the zero insertion force connector by flipping up the locking flap and pulling the cable out.
  15. Asus Z54C-JS31 Motherboard Replacement: 步骤 15 中的图像 1,3 Asus Z54C-JS31 Motherboard Replacement: 步骤 15 中的图像 2,3 Asus Z54C-JS31 Motherboard Replacement: 步骤 15 中的图像 3,3
    • Remove the two 5mm screws holding the motherboard and fan in place.
    • Lift out the motherboard and fan.
结论
Mark DeSimone
于10/19/17注册
801 声望
创作了8篇指南
团队
UMass Dartmouth, Team S3-G1, Bailey Fall 2017 UMass Dartmouth, Team S3-G1, Bailey Fall 2017 的会员
UMASSD-BAILEY-F17S3G1
2 名成员
创作了8篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 17
总计 573
