简介
If you're having trouble with your laptop turning on or holding a charge then you may need to change the battery. This guide will help you to replace the battery.
你所需要的
Turn the laptop upside down and locate the ten screws holding in the plate cover.
Remove all ten screws using a small Phillips head screwdriver.
即将完成!
结论
