跳转到主内容
简介
This guide will assist you in replacing a faulty wireless card in your ASUS X751L.
  1. With the screen closed, place your laptop upside-down with the front facing you.
    • With the screen closed, place your laptop upside-down with the front facing you.
    • Remove the six 14.6mm Phillips #00 screws.
    • Remove the four 6.6mm Phillips #00 screws.
  2. Flip the laptop over and open the lid.
    • Flip the laptop over and open the lid.
    • Pry around the edges of the laptop base using the plastic opening tool.
    • Prying too hard can break the plastic clips.
  3. Android 维修工具包
    一个新的屏幕或电池就在一个套件之内。
    现在开始购物
    Android 维修工具包
    一个新的屏幕或电池就在一个套件之内。
    现在开始购物
  4. Carefully lift the keyboard up. Be very careful when lifting the keyboard up. Two zero insertion force (ZIF) cables are between the keyboard assembly and the motherboard. Do not lift the assembly too high. Disconnect the two ZIF connectors from the motherboard using your fingernail to lift the cream-colored tab.
    • Carefully lift the keyboard up.
    • Be very careful when lifting the keyboard up. Two zero insertion force (ZIF) cables are between the keyboard assembly and the motherboard. Do not lift the assembly too high.
    • Disconnect the two ZIF connectors from the motherboard using your fingernail to lift the cream-colored tab.
  5. Remove the single 4.7mm PH00 screw holding the wireless card to the motherboard.
    • Remove the single 4.7mm PH00 screw holding the wireless card to the motherboard.
  6. Using your fingers, lightly lift up on the black and white antenna cords.
    • Using your fingers, lightly lift up on the black and white antenna cords.
  7. With your fingers lightly pull the wireless card out of the slot.
    • With your fingers lightly pull the wireless card out of the slot.
    • Make sure to keep the card parallel with the motherboard when removing from the slot.
结论
2等其他人完成本指南。
Matthew Martin
于2017年02月02日注册
185 信誉积分
撰写一个指南
团队
USF Tampa, Team 17-2, Blackwell Spring 2017 USF Tampa, Team 17-2, Blackwell Spring 2017 的会员
USFT-BLACKWELL-S17S17G2
4 名成员
创作了5篇指南
添加评论
浏览统计数据:
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 19
总计 977
