跳转到主内容
Asus X751L Screen Replacement
你所需要的
  1. Asus X751L Screen Replacement, Keyboard: 步骤 1 中的图像 1,1
    • With the screen closed, place your laptop upside-down with the front facing you.
    • Remove the six 14.6mm Phillips #00 screws.
    • Remove the four 6.6mm Phillips #00 screws.
  2. Asus X751L Screen Replacement: 步骤 2 中的图像 1,1
    • Flip the laptop over and open the lid.
    • Pry around the edges of the laptop base using the plastic opening tool.
    • Prying too hard can break the plastic clips.
  3. Asus X751L Screen Replacement: 步骤 3 中的图像 1,3 Asus X751L Screen Replacement: 步骤 3 中的图像 2,3 Asus X751L Screen Replacement: 步骤 3 中的图像 3,3
    • Carefully lift the keyboard up.
    • Be very careful when lifting the keyboard up. Two zero insertion force (ZIF) cables are between the keyboard assembly and the motherboard. Do not lift the assembly too high.
    • Disconnect the two ZIF connectors from the motherboard using your fingernail to lift the cream-colored tab.
  4. Asus X751L Screen Replacement, Screen: 步骤 4 中的图像 1,2 Asus X751L Screen Replacement, Screen: 步骤 4 中的图像 2,2
    • Remove the two rubber screw covers and the Phillips #00 screws beneath them.
  5. Asus X751L Screen Replacement: 步骤 5 中的图像 1,1
    • Pry around the edges of the panel using the plastic opening tool.
    • Carefully pull off the screen cover.
  6. Asus X751L Screen Replacement: 步骤 6 中的图像 1,2 Asus X751L Screen Replacement: 步骤 6 中的图像 2,2
    • Remove the two 4.7mm Phillips#00 screws to free the screen-holding bracket from the back panel.
  7. Asus X751L Screen Replacement: 步骤 7 中的图像 1,3 Asus X751L Screen Replacement: 步骤 7 中的图像 2,3 Asus X751L Screen Replacement: 步骤 7 中的图像 3,3
    • Remove the four 3.6mm Phillips#00 screws on the right side of the screen.
    • Remove the four 3.6mm Phillips#00 screws on the left side of the screen.
    • Make sure you hold the screen so it doesn't fall forward when removed from the bracket.
  8. Asus X751L Screen Replacement: 步骤 8 中的图像 1,2 Asus X751L Screen Replacement: 步骤 8 中的图像 2,2
    • Gently lay the screen down to reveal the back side.
    • Remove the tape over top of the display cable connector.
    • Disconnect the display cable connector using your fingers.
结论
8等其他人完成本指南。
Sanwal Hussain
于02/05/17注册
231 声望
撰写一个指南
团队
USF Tampa, Team 17-2, Blackwell Spring 2017 USF Tampa, Team 17-2, Blackwell Spring 2017 的会员
USFT-BLACKWELL-S17S17G2
4 名成员
创作了5篇指南
2条评论
Great presentation. My screen develops purple and pink vertical lines and no picture but if I adjust screen backward or forwards it clears up…but the problem is getting worse. Another observation is that if I apply a lot of pressure on area between the power button and the left hinge that it will clear up at certain angles of the screen.
Is it possible/probable that I have a loose connection below that pressure point where the screen cable connects with the computer board or is it more likely that the cable has simply worn out and the wires are actually breaking? Or is there another conclusion?
Scott
wscottsnyder@gmail.com
Scott Snyder - 回复
great pictures, how do i solve my screen if it is completely disturbed but gets back to normal if i press the base on the left front corner,
it also helps if i move the screen forward and backward.
does someone has a recommendation what to do, or what the root/cause is? It happens more often every week.
Harm - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 34
总计 5,201
