跳转到主内容
Asus X751L DVD Drive Replacement
你所需要的
  1. Asus X751L DVD Drive Replacement, Keyboard: 步骤 1 中的图像 1,1
    • With the screen closed, place your laptop upside-down with the front facing you.
    • Remove the six 14.6mm Phillips #00 screws.
    • Remove the four 6.6mm Phillips #00 screws.
  2. Asus X751L DVD Drive Replacement: 步骤 2 中的图像 1,1
    • Flip the laptop over and open the lid.
    • Pry around the edges of the laptop base using the plastic opening tool.
    • Prying too hard can break the plastic clips.
  3. Asus X751L DVD Drive Replacement: 步骤 3 中的图像 1,3 Asus X751L DVD Drive Replacement: 步骤 3 中的图像 2,3 Asus X751L DVD Drive Replacement: 步骤 3 中的图像 3,3
    • Carefully lift the keyboard up.
    • Be very careful when lifting the keyboard up. Two zero insertion force (ZIF) cables are between the keyboard assembly and the motherboard. Do not lift the assembly too high.
    • Disconnect the two ZIF connectors from the motherboard using your fingernail to lift the cream-colored tab.
  4. Asus X751L DVD Drive Replacement, DVD Drive: 步骤 4 中的图像 1,1
    • With the keyboard panel open, face the laptop with the internal components facing towards you.
    • Remove the single 4.6mm Phillips #00 screw.
  5. Asus X751L DVD Drive Replacement: 步骤 5 中的图像 1,1
    • Pull the optical drive out.
结论
2等其他人完成本指南。
Carl Ravina
于02/02/17注册
125 声望
撰写一个指南
团队
USF Tampa, Team 17-2, Blackwell Spring 2017 USF Tampa, Team 17-2, Blackwell Spring 2017 的会员
USFT-BLACKWELL-S17S17G2
4 名成员
创作了5篇指南
一条评论
Spot on, took away any worries…………
paul pepper - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 2,308
