跳转到主内容
Asus X751L Battery Replacement
你所需要的
  1. Asus X751L Battery Replacement, Keyboard: 步骤 1 中的图像 1,1
    • With the screen closed, place your laptop upside-down with the front facing you.
    • Remove the six 14.6mm Phillips #00 screws.
    • Remove the four 6.6mm Phillips #00 screws.
  2. Asus X751L Battery Replacement: 步骤 2 中的图像 1,1
    • Flip the laptop over and open the lid.
    • Pry around the edges of the laptop base using the plastic opening tool.
    • Prying too hard can break the plastic clips.
  3. Asus X751L Battery Replacement: 步骤 3 中的图像 1,3 Asus X751L Battery Replacement: 步骤 3 中的图像 2,3 Asus X751L Battery Replacement: 步骤 3 中的图像 3,3
    • Carefully lift the keyboard up.
    • Be very careful when lifting the keyboard up. Two zero insertion force (ZIF) cables are between the keyboard assembly and the motherboard. Do not lift the assembly too high.
    • Disconnect the two ZIF connectors from the motherboard using your fingernail to lift the cream-colored tab.
  4. Asus X751L Battery Replacement, Battery: 步骤 4 中的图像 1,1
    • Remove the two 6.6mm Phillips #00 screws holding the battery in place.
  5. Asus X751L Battery Replacement: 步骤 5 中的图像 1,2 Asus X751L Battery Replacement: 步骤 5 中的图像 2,2
    • Lift the battery from the cable-side to maneuver it around the plastic clips.
  6. Asus X751L Battery Replacement: 步骤 6 中的图像 1,3 Asus X751L Battery Replacement: 步骤 6 中的图像 2,3 Asus X751L Battery Replacement: 步骤 6 中的图像 3,3
    • Using your finger nails, gently push the battery cable out of the connector on the motherboard.
    • Once the cable is disconnected, you can remove the battery.
结论
4等其他人完成本指南。
John Enderton
于02/02/17注册
576 声望
创作了2篇指南
团队
USF Tampa, Team 17-2, Blackwell Spring 2017 USF Tampa, Team 17-2, Blackwell Spring 2017 的会员
USFT-BLACKWELL-S17S17G2
4 名成员
创作了5篇指南
6条评论
Very nice, thank you !
anh
barzamjavel - 回复
very nice, thank you !
Anh
barzamjavel - 回复
Took me awhile to figure out how to get the cables back. Other than that, good insturctions.
Jacqueline Foxall - 回复
Your instructions were easy to follow. Thank you!!!
theresa collet - 回复
very helpful
khan - 回复
What do the yellow and white wires do ?
Richard Sullivan - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 15
过去 30 天: 53
总计 12,758
