简介
We will show you how to open the laptop and change / upgrade the HDD (hard disk drive).
你所需要的
视频概述
Switch off the Laptop and remove the Battery.
Unscrew the two Philips screws and remove the HDD / RAM Cover.
Remove the two Philips screws and separate the HDD from the caddy case.
You can install 2.5" SATA HDD, 5400rpm / 7200rpm, 320GB / 500GB / 750GB /1TB.
Did you do it successfully.
Okay so I was needing to upgrade hdd on this exact model and it worked great for the first part but putting the cover on didn’t work any ideas?
4等其他人完成本指南。
一条评论
Were do you get the OS already installed on the drive. I have a Asus 550 with a 500 G and win 8.1. Looking to up grade to win 10 YES i have the GEO FORCE graphic card. Will I loose the use of the GEO FORCE. card. It has a i7 chip. And 6 g of line one cache would like to take to like 16 G… I would like to use the solid state hard drive. I understand it weathers bounces. Small slams and bangs better than the disc type. But I may not beable to afford this high a upgrade. Recommendations chrisdeiotte7@gmail.com
