跳转到主内容
Asus X55C HDD (Hard Disk Drive) Replacement
你所需要的
视频概述
  1. Asus X55C HDD (Hard Disk Drive) Replacement, HDD (Hard Disk Drive): 步骤 1 中的图像 1,3 Asus X55C HDD (Hard Disk Drive) Replacement, HDD (Hard Disk Drive): 步骤 1 中的图像 2,3 Asus X55C HDD (Hard Disk Drive) Replacement, HDD (Hard Disk Drive): 步骤 1 中的图像 3,3
    • Switch off the Laptop and remove the Battery.
    • Unscrew the two Philips screws and remove the HDD / RAM Cover.
  2. Asus X55C HDD (Hard Disk Drive) Replacement: 步骤 2 中的图像 1,3 Asus X55C HDD (Hard Disk Drive) Replacement: 步骤 2 中的图像 2,3 Asus X55C HDD (Hard Disk Drive) Replacement: 步骤 2 中的图像 3,3
    • Remove three screws securing the hard drive caddy (hard drive assembly).
    • Slide the hard drive assembly to the left to disconnect it from the motherboard.
  3. Asus X55C HDD (Hard Disk Drive) Replacement: 步骤 3 中的图像 1,1
    • Remove the two Philips screws and separate the HDD from the caddy case.
    • You can install 2.5" SATA HDD, 5400rpm / 7200rpm, 320GB / 500GB / 750GB /1TB.
    • After changing / upgrading the HDD you must install an operating system or clone & copy the information from the old HDD to the new one.
    • Did you do it successfully.
    • Please SUBSCRIBE to my channel ツ
结论
4等其他人完成本指南。
ZFix
于12/09/13注册
190,079 声望
创作了330篇指南
团队
Master Techs Master Techs 的会员
Community
319 名成员
创作了1,354篇指南
一条评论
Were do you get the OS already installed on the drive. I have a Asus 550 with a 500 G and win 8.1. Looking to up grade to win 10 YES i have the GEO FORCE graphic card. Will I loose the use of the GEO FORCE. card. It has a i7 chip. And 6 g of line one cache would like to take to like 16 G… I would like to use the solid state hard drive. I understand it weathers bounces. Small slams and bangs better than the disc type. But I may not beable to afford this high a upgrade. Recommendations chrisdeiotte7@gmail.com
Chris Deiotte - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 41
总计 11,248
