跳转到主内容
Fix Your Stuff
Right to Repair
Parts & Tools
简介
How to disassemble the laptop and replace the CMOS / BIOS Battery.
__________________ Video manual: __________________
视频概述
  1. Switch off the laptop and remove the battery.
    • Switch off the laptop and remove the battery.
  2. The Keyboard is held by 5x locking clips. Pick up a little the one side of the Keyboard and start opening the clips one by one. Disconnect the Keyboard flex cable from the mother board and remove the KB.
    • The Keyboard is held by 5x locking clips.
    • Pick up a little the one side of the Keyboard and start opening the clips one by one.
    • Disconnect the Keyboard flex cable from the mother board and remove the KB.
    • Please SUBSCRIBE to my channel ツ
  3. Remove the screw. Pull out the SATA DVD Drive.
    • Remove the screw.
    • Pull out the SATA DVD Drive.
  4. Remove 3x Philips screws. Disconnect the two small flex cables:
    • Remove 3x Philips screws.
    • Disconnect the two small flex cables:
    • Power On button flex cable
    • Touch pad flex cable
  5. Unscrew the two Philips screws and remove the HDD / RAM Cover. Remove three screws securing the hard drive caddy (hard drive assembly). Slide the hard drive assembly to the left to disconnect it from the motherboard.
    • Unscrew the two Philips screws and remove the HDD / RAM Cover.
    • Remove three screws securing the hard drive caddy (hard drive assembly).
    • Slide the hard drive assembly to the left to disconnect it from the motherboard.
  6. Disconnect the two coaxial antenna cables from the Wi-Fi card. Remove any Memory or Dummy card.
    • Disconnect the two coaxial antenna cables from the Wi-Fi card.
    • Remove any Memory or Dummy card.
  7. The bottom cover is held by 10x Phillips screws. Remove them. With a plastic tool separate the Upper cover and remove it. With a plastic tool separate the Upper cover and remove it.
    • The bottom cover is held by 10x Phillips screws. Remove them.
    • With a plastic tool separate the Upper cover and remove it.
  8. Disconnect: The Microphone cable The LCD Display flex cable
    • Disconnect:
    • The Microphone cable
    • The LCD Display flex cable
    • Remove 3x Pillips screws.
    • Lift the board first from the right edge.
    • There is another one cable, from the DC connector, connected to the underside of main board. We should spun the the board to disconnect the DC connector cable.
  9. ASUS X55C iCore with 4GB no board RAM motherboard, model: 60-N0OMB1100 Please SUBSCRIBE to my channel  ツ
  10. Use a sharp tool to remove the Battery. CR2032 -  button cell lithium battery rated at 3.0 volts. Did you do it successfully?
结论
6等其他人完成本指南。
ZFix
于2013年12月09日注册
168,494 信誉积分
创作了306篇指南
团队
Master Techs Master Techs 的会员
Community
291 名成员
创作了831篇指南
添加评论
浏览统计数据:
过去的24小时: 6
过去的7天: 31
过去的30天: 112
总计 12,440
