当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Use the plastic opening tool to separate the top cover from the laptop.
Start by prying on the front of the laptop.
Continue prying around the cover and end just under the screen to release the front cover.
Do not fully remove the top cover, it is attached by two ribbon cables that will be disconnected in the following steps.
To release the ZIF latch, flip up the small white tab.
The connector may have a white base with a small grey rotating latch.
Pull the white ribbon cable out of the socket to disconnect it.
Very little force should be required to pull out the cable.
To release the ZIF latch on the keyboard cable, flip the grey rotating tab up.
Gently pull the black and blue ribbon cable out of its connector.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
