跳转到主内容
Asus X553MA-BPD07051 RAM Replacement
你所需要的
  1. Asus X553MA-BPD07051 RAM Replacement, Battery: 步骤 1 中的图像 1,2 Asus X553MA-BPD07051 RAM Replacement, Battery: 步骤 1 中的图像 2,2
    • Use a Phillips #0 screwdriver (PH0 bit) to remove the four 5.0 mm screws that are securing the bottom of the laptop.
    • Use a Phillips #0 screwdriver (PH0 bit) to remove the six 11.0 mm screws that are securing the bottom of the laptop.
  2. Asus X553MA-BPD07051 RAM Replacement: 步骤 2 中的图像 1,1
    • Lift the edges of the keyboard using the plastic iFixit opening tool and raise the keyboard slightly to see the inside of the laptop.
    • Do not lift the keyboard too high as the keyboard is connected to the motherboard by two ribbon connectors that must be detached.
  3. Asus X553MA-BPD07051 RAM Replacement: 步骤 3 中的图像 1,2 Asus X553MA-BPD07051 RAM Replacement: 步骤 3 中的图像 2,2
    • Lift back the clip on the ribbon tape, and pull the tape out in order to remove the keyboard from the laptop.
    • Remove both pieces of the ribbon tape connecting the keyboard to the motherboard.
  4. Asus X553MA-BPD07051 RAM Replacement: 步骤 4 中的图像 1,1
    • Remove the bundled cable connector attaching the battery to the motherboard with the plastic iFixit opening tool.
    • Make sure that you do not remove the entire connector by applying too much force. Only the white plastic connector should be removed from the metal part on the motherboard.
  5. Asus X553MA-BPD07051 RAM Replacement: 步骤 5 中的图像 1,2 Asus X553MA-BPD07051 RAM Replacement: 步骤 5 中的图像 2,2
    • Use Phillips #0 screwdriver (PH0 bit) to remove the four 6.0 mm screws attaching the battery to the laptop.
  6. Asus X553MA-BPD07051 RAM Replacement: 步骤 6 中的图像 1,2 Asus X553MA-BPD07051 RAM Replacement: 步骤 6 中的图像 2,2
    • Lift the battery up and remove it completely from the laptop.
  7. Asus X553MA-BPD07051 RAM Replacement, Hard Drive: 步骤 7 中的图像 1,2 Asus X553MA-BPD07051 RAM Replacement, Hard Drive: 步骤 7 中的图像 2,2
    • Use a Phillips #0 screwdriver (PH0 bit) to remove the four 6.0 mm screws that are securing the hard drive.
  8. Asus X553MA-BPD07051 RAM Replacement: 步骤 8 中的图像 1,2 Asus X553MA-BPD07051 RAM Replacement: 步骤 8 中的图像 2,2
    • Lift the hard drive up and pull it towards the screen so that it disconnects from the motherboard.
    • Use caution when disconnecting the hard drive from the motherboard, so that neither connector gets broken.
  9. Asus X553MA-BPD07051 RAM Replacement, Optical Drive: 步骤 9 中的图像 1,2 Asus X553MA-BPD07051 RAM Replacement, Optical Drive: 步骤 9 中的图像 2,2
    • Use a Phillips #0 screwdriver (PH0 bit) to remove the one 6.0 mm screw holding in the optical drive.
  10. Asus X553MA-BPD07051 RAM Replacement: 步骤 10 中的图像 1,2 Asus X553MA-BPD07051 RAM Replacement: 步骤 10 中的图像 2,2
    • Gently slide the optical drive out from the motherboard.
  11. Asus X553MA-BPD07051 RAM Replacement, Motherboard: 步骤 11 中的图像 1,3 Asus X553MA-BPD07051 RAM Replacement, Motherboard: 步骤 11 中的图像 2,3 Asus X553MA-BPD07051 RAM Replacement, Motherboard: 步骤 11 中的图像 3,3
    • Remove the bundled cable connector that connects the fan to the motherboard using the plastic iFixit opening tool.
    • Remove the bundled cable connector that attaches the audio to the motherboard with the plastic iFixit opening tool.
  12. Asus X553MA-BPD07051 RAM Replacement: 步骤 12 中的图像 1,2 Asus X553MA-BPD07051 RAM Replacement: 步骤 12 中的图像 2,2
    • Lift the metal clip holding the ZIF connector ribbon down.
    • Pull the ribbon out from the connector, away from the motherboard.
  13. Asus X553MA-BPD07051 RAM Replacement: 步骤 13 中的图像 1,2 Asus X553MA-BPD07051 RAM Replacement: 步骤 13 中的图像 2,2
    • Use a Phillips #0 screwdriver (PH0 bit) to remove the five 6.0 mm screws attaching the motherboard to the base of the laptop.
  14. Asus X553MA-BPD07051 RAM Replacement: 步骤 14 中的图像 1,1
    • Remove the tape from the motherboard.
  15. Asus X553MA-BPD07051 RAM Replacement: 步骤 15 中的图像 1,2 Asus X553MA-BPD07051 RAM Replacement: 步骤 15 中的图像 2,2
    • Lift the metal clips holding the ZIF connector down.
    • Push the gold metal connector away from the motherboard.
    • Be careful not to break the connector.
  16. Asus X553MA-BPD07051 RAM Replacement: 步骤 16 中的图像 1,2 Asus X553MA-BPD07051 RAM Replacement: 步骤 16 中的图像 2,2
    • Lift the coaxial connector from the wifi chip with the plastic iFixit opening tool.
  17. Asus X553MA-BPD07051 RAM Replacement: 步骤 17 中的图像 1,3 Asus X553MA-BPD07051 RAM Replacement: 步骤 17 中的图像 2,3 Asus X553MA-BPD07051 RAM Replacement: 步骤 17 中的图像 3,3
    • Lift the motherboard to remove it fully.
    • Do not pull too hard, the motherboard should come off easily once it has been separated from the base of the laptop.
  18. Asus X553MA-BPD07051 RAM Replacement, RAM: 步骤 18 中的图像 1,3 Asus X553MA-BPD07051 RAM Replacement, RAM: 步骤 18 中的图像 2,3 Asus X553MA-BPD07051 RAM Replacement, RAM: 步骤 18 中的图像 3,3
    • Remove the RAM by lifting and pulling it up from the back of the motherboard.
结论
2等其他人完成本指南。
团队
UMass Dartmouth, Team S1-G4, Botvin Fall 2019 UMass Dartmouth, Team S1-G4, Botvin Fall 2019 的会员
UMASSD-BOTVIN-F19S1G4
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 19
总计 1,557
